Acidity of Alcohols: Understanding the Reaction
  • Thread starter Quotes
  • Tags
    Alcohols
In summary: I am not sure that is what you are asking. I liked that because it did relate to some experimental fact. Maybe the student doesn't have any sodium ethoxide to hand though so what does happen? I suppose it warms up as protons are lost from H2O and protonate the ethoxide ion. If instead you added ethanol to NaOH there is no disequilibrium and nothing much should happen.Anyway you would have to have some sodium ethoxide to start with.
Quotes
30
Please post this type of questions in HW section using the template.
I have read from a book that from the following reaction
H2O + R-O- - - - - > R-O-H + O--H
We can conclude that water is a better proton donor (Bronsted acid) than alcohol.
But how did they conclude so?
I can figure out the reason on basis of electronegativity concepts but how to do so from the reaction.
Please help.
Likes epenguin
Add sodium ethoxide to water, observe what happens.
Likes Quotes and epenguin
In the above reaction, there is an equilibrium going on. In the forward direction, water is acting as an acid and the alkoxide is acting as a base. In the reverse direction, the alcohol is acting as the acid and the hydroxide as the base. The fact that the equilibrium strongly favors the forward direction tells you about the relative acidity of water versus alcohols.
Likes Quotes
Thanks
Thankyou so much. I got my doubts cleared very well.
I liked that because it does relate to some experimental fact. Maybe the student doesn't have any sodium ethoxide to hand though so what does happen? I suppose it warms up as protons are lost from H2O and protonate the ethoxide ion. If instead you added ethanol to NaOH there is no disequilibrium and nothing much should happen.
Anyway you would have to have some sodium ethoxide to start with. I also liked that because it stirred a very faded memory of my chemistry teacher showing adding sodium to ethanol - we could see it react like water but much more feebly!
(I probably at the time would not have thought to ask about whether the alcohol was dry. A less faded memory is a year or two later in an industrial laboratory we kept solvents dry by extruding a wire of fresh sodium into them with a 'sodium press'. Never having been in a lab with that necessity since I don't know whether this is commonly done.)
Please help.
Due to new computer I lost the first half of my reply which was to say you may well ask - you have read this in a book, I have read it in books and now on sites and it appears to me that if your question is about any experimental support or manifestation of ethanol acidity, amongst the many the books and sites with much to say about alcohol acidity, those that tell you anything about the answer to your question appear to me a very small minority. A book I have with a chapter about mostly organic compounds acidity/basicity, and many about their consequences, mentions ethanol's pK in water) of 15.9. Looking hard I find such pKs have to be determined 'by indirect methods'.
Perhaps some rare book tells of these. I am not rarely struck by a contrast between textbooks' overslidings like this and their Sunday sermons on p.1 about the paramountcy of experiment and its evidence.*something weird happened, when I press Edit I can still see my 1st paragraph but otherwise not.
What is the acidity of alcohols?
The acidity of alcohols refers to their ability to donate a proton (H+) in a chemical reaction. This is determined by the strength of the O-H bond in the alcohol molecule.
How does the acidity of alcohols compare to other compounds?
Alcohols are generally less acidic than acids such as carboxylic acids, but more acidic than alkanes. This is due to the electronegativity of the oxygen atom in the alcohol molecule.
What factors affect the acidity of alcohols?
The acidity of an alcohol can be affected by the type of alcohol (primary, secondary, or tertiary), the presence of electron-withdrawing groups, and the solvent used in the reaction.
Why is understanding the acidity of alcohols important?
Understanding the acidity of alcohols is important in organic chemistry as it can determine the reactivity and behavior of alcohols in chemical reactions. It can also help predict the products of these reactions.
How can the acidity of alcohols be measured?
The acidity of alcohols can be measured using techniques such as titration, where a known base is added to the alcohol and the amount of base needed to neutralize the acid is measured. This can give an idea of the strength of the O-H bond in the alcohol molecule.
