Homework Help: Acrobat and monkey
  1. Sep 28, 2016 #1
    A circus acrobat of mass ##M## leaps straight up with initial velocity ##v_0## from the trampoline. As he rises up, he takes a trained monkey of mass ##m## off a perch at a height ##h## above the trampoline. What is the maximum height attained by the pair?
    2. Relevant equations
    3. The attempt at a solution
    This is a pretty simple problem. All we do is derive a new initial velocity from the conservation of momentum, and then calculate the h that results when the masses are combined. However, I am wondering why using the conservation of momentum is justified, since the system is not isolated because there is gravity acting in the y-direction. Thus, why can I use the conservation of momentum in the y-direction when the man and monkey collide?
  3. Sep 28, 2016 #2
    gneill
    Staff: Mentor
    What is the assumption that is made for the time it takes for a collision to occur? What change in gravitational PE is expected over that time interval?
  4. Sep 28, 2016 #3
    Ah, okay. So in the very small limit of the time of collision momentum is conserved.
  5. Sep 28, 2016 #4
    gneill
    Staff: Mentor
    Right. In particular, it occurs in a small enough time interval that there is no work done by gravity during the process as the objects don't move (noticeably) higher or lower in the gravitational field.
Have something to add?
Draft saved Draft deleted
