- #71
Dale
Mentor
- 35,232
- 13,453
This is a commonly-repeated phrase, but it is not true. Current always takes all paths.somasimple said:current always takes the path of least resistance.
I have no idea what you are trying to say. Why should an experiment cost less than $1?somasimple said:give results from experiments that costs less than 1$ each.
In an electronic circuit the charge carriers (electrons) are are free to move in the metal. In the neuron the charge carriers (cations) are are free to move in the electrolyte. The electrolytical fluid takes the place of the metal.somasimple said:OK, let's suppose that membrane is a capacitor:
1/ Where are the metal planes?
2/ Where are the wires?
Yes. However there is also leakage current which occurs across the membrane as well as in commercial capacitorssomasimple said:3/ In a capacitor, current flows through wires and circuit, is it the same with membrane?
What do you mean?somasimple said:4/ In a capacitor, dielectric insulates the two metal plates. In membrane, dielectric allows the whole currents fluxes, why?
No, the charge carriers are primarily cations as I mentioned above.somasimple said:5/ In a capacitor current is made from electrons, is it the same?
Yes.somasimple said:6/ In a capacitor, the distributed charges are symmetric, is it the same?
Please try again, there is a language problem and I didn't understand what you are asking. What are you trying to say with the word "vertical"?somasimple said:7/ in a capacitor, exchanges occur exclusively (except leakage current) through wires and are vertical, how are you able to enable also (in propagation) a transversal one and what rules does it follow?
No, the capacitor represents the capacitance of the membrane. The resistors represent the concudtance of the ion channels. And the batteries represent the Nernst potential of the bulk concentration gradients.somasimple said:8/ In your schematic, capacitor is associated with ions channels (resistances). Since wires are in both cases situated in the "capacitor plates", how do you connect them?
What do you mean by "associated to"? And what do you mean by "under their entry point"? Is this somehow related to the "vertical" from above?somasimple said:9/ since AP requires only a tiny 0.04 % of available ions, why do they choose to be associated to their far neighbors from the right or the left since there is closer ones just under their entry point?
Please try to take things slowly. Your questions don't seem to be unanswerable, but there is a considerable language barrier. I know it is hard to express things in a forigen language, and your English is much better than my French, but even so it is probably better to spend the effort to make one clear major question than to make 9 confusing or minor questions.
In any case, the bottom line is that the HH model works quite well. You are certainly free to propose a model which works even better, but in the absence of a better model it is somewhat silly to object so strenuously to this one.
