What happens to the Na+ ions during an action potential?
In summary: This is why the decay phase is so slow- because the K+ channels are not activated as quickly as the Na+ channels.In summary, during an action potential, Na+ ions enter the cell and stay there for a while until they are pumped out by the Na/K ATPase pump. The process happens because Na ions channels are open, but the channels become inactivated/closed for a while. What happens to the Na+ ions that entered the cell is that they stay there for the time being until they are actively pumped back out of the cell by the Na/K ATPase pump. This explanation contradicts twice the facts- first that Na K pumps are
  • #71
somasimple said:
current always takes the path of least resistance.
This is a commonly-repeated phrase, but it is not true. Current always takes all paths.
somasimple said:
give results from experiments that costs less than 1$ each.
I have no idea what you are trying to say. Why should an experiment cost less than $1?
somasimple said:
OK, let's suppose that membrane is a capacitor:
1/ Where are the metal planes?
2/ Where are the wires?
In an electronic circuit the charge carriers (electrons) are are free to move in the metal. In the neuron the charge carriers (cations) are are free to move in the electrolyte. The electrolytical fluid takes the place of the metal.
somasimple said:
3/ In a capacitor, current flows through wires and circuit, is it the same with membrane?
Yes. However there is also leakage current which occurs across the membrane as well as in commercial capacitors
somasimple said:
4/ In a capacitor, dielectric insulates the two metal plates. In membrane, dielectric allows the whole currents fluxes, why?
What do you mean?
somasimple said:
5/ In a capacitor current is made from electrons, is it the same?
No, the charge carriers are primarily cations as I mentioned above.
somasimple said:
6/ In a capacitor, the distributed charges are symmetric, is it the same?
Yes.
somasimple said:
7/ in a capacitor, exchanges occur exclusively (except leakage current) through wires and are vertical, how are you able to enable also (in propagation) a transversal one and what rules does it follow?
Please try again, there is a language problem and I didn't understand what you are asking. What are you trying to say with the word "vertical"?
somasimple said:
8/ In your schematic, capacitor is associated with ions channels (resistances). Since wires are in both cases situated in the "capacitor plates", how do you connect them?
No, the capacitor represents the capacitance of the membrane. The resistors represent the concudtance of the ion channels. And the batteries represent the Nernst potential of the bulk concentration gradients.
somasimple said:
9/ since AP requires only a tiny 0.04 % of available ions, why do they choose to be associated to their far neighbors from the right or the left since there is closer ones just under their entry point?
What do you mean by "associated to"? And what do you mean by "under their entry point"? Is this somehow related to the "vertical" from above?
Please try to take things slowly. Your questions don't seem to be unanswerable, but there is a considerable language barrier. I know it is hard to express things in a forigen language, and your English is much better than my French, but even so it is probably better to spend the effort to make one clear major question than to make 9 confusing or minor questions.
In any case, the bottom line is that the HH model works quite well. You are certainly free to propose a model which works even better, but in the absence of a better model it is somewhat silly to object so strenuously to this one.
Biology news on Phys.org
  • #72
I will reply to the first statement because the subsequent responses will be useless if you do not solve this one.
Yes, current flows in all paths but prefers the least resistances.
So you admit the situation but I said I wasn't kind and it was a rude question.
So we said that entering ions are associated with their opposite counterions. The most of them are just under and some will make the job onto the right and onto the left.
NO! It can't work at all.
If I accept that a ion is associated in the internal milieu of the cell, I must also accept it was also the case, outside. That makes a big problem. You must, now, consider, that ions were also associated, outside.
Then, you must also fill the gap of initial conditions (IC); A solution where energy is low and where the model may function.
Of course, there is one with the hypothesis:
All ions are associated, on each side!
You solve the problem of electronegativity but you may encounter some bigger ones:
You have now salt crystals on each side of the cell.
Bad new for diffusion and too bad for currents: It is also a well known thing that crystals are effectively neutral but very good... insulators for the same reason.
This point of view has not my preference: I prefer water bondings for salts...
  • #73
I don't like using human psychological terms like "prefers" to describe inanimate objects. I would say that current goes through all paths, but more current goes through the path of least resistance than through the other paths. This makes it clear that current is going through all paths and still covers the essence of the "path of least resistance" concept.
  • #74
The criticism is well received but the model remains still invalid.
  • #75
You still haven't explained about what you mean by "associated".
I don't understand how you make the completely random jump to salt formation. It is certainly not based on any understanding of correct physics. Do you understand how a salt crystal dissolves or forms in a good polar solvent like water?
I am sorry, but you are completely mistaken. Do you understand what it means for a salt solution to be an electrolyte? It means precisely that you get both ionic currents and diffusion even even with both cations and anions present in the solution. This isn't even a biological phenomenon, it is simple high-school level chemistry. The concentrations are way to low to get salt formation, and there is diffusion and electrical conduction via ionic currents.
  • #76
No it is not invalid. It fits a wide range of experimental data within its domain of applicability. That is all that is required to validate a scientific model. I am having a hard time following your objections, but the simple fact remains that the HH model works. Therefore it is valid. End of story.
If you make any model (it doesn't have to have any physical inspiration as the HH model does), propose a hypothesis based on the model, perform the experiment, and get data supporting the hypothesis, then the model is validated. That is the nature of science.
As you perform more experiments you may get some experiments that don't match the model. Then you learn the limits of the domain of applicability for the model. That still doesn't make the model invalid within its already scientifically validated domain.
Some later person (like yourself) may come up with a better model that fits all the data including this new domain and, if the new model is valid, it must agree with the old model within the old model's limited domain. Such is the nature of the scientific method.
  • #77
I do not understand how you produce an equal charge of opposite sign when you move (i.e) a Na+ ion from outside to inside.
My attempt was clearly silly as the model.
Perhaps you think that Na+ let's a "free" electron on the opposite side?
  • #78
More simply,
with a simple example: KCl and water with a semi permeable membrane to K+. (High school).
IC:
The KCl is on the left (membrane at center).
Terminal conditions:
  1. Some K+ ions are at right and
  2. membrane is now polarized (becomes a capacitor).
Problem:
Describe how you obtain the second result?
  • #79
  • #80
No, in an electrolyte the primary charge carriers are dissolved ions. However, I don't understand why you think moving an ion from one side to the other should "produce" an equal charge of opposite sign. Since the electrolyte is, in bulk, electroneutral you know that there is already an anion in solution for every cation. So no anion needs to be produced, they already exist in the solution.
IC:
Problem:
Do you know the concept of http://en.wikipedia.org/wiki/Amperes_Law" to be useful. This is a very fundamental set of concepts that apply to many different systems, not just neurons. So I would most strongly encourage you to study this until you understand how the second result happens, but you will probably need to branch out beyond the links I have provided. Please, familiarize yourself with the fundamental concepts and post any follow-up questions that you have.
  • #81
I know you consider that I'm an idiot.
Consider that I'm stubborn, too!
I'm now facing with a strange behavior from your own: Every time we're close to get, at last, a reply, you change abruptly and bring a ton of useless material that has nothing to see with the current question.
So, I'll restate one more time my simple "virtual" and well known experiment:
Two compartments are separated by a semi-permeable membrane oriented to the "water" side (semi permeable for K+).
IC:
compartment one contains water.
compartment two is filled with a solution of KCl (potassium chloride). Concentration doesn't matters but we will take 40 mM.
The membrane capacitor is supposed discharged, right?
http://nerve.bsd.uchicago.edu/rp1.htm
Then,
At a time t1, since some K+ have moved and now, the membrane must carry some charges since we have a potential difference?
Please describe the charges carried on each side (if needed) of the membrane that explains it functions as a capacitor and maintains charges?
Hope the question is sufficiently clear?
  • #82
It doesn't matter how many of his questions that you answer. He doesn't think there's something in particular wrong with our understanding of action potential generation / propagation in neurons. Instead he's sure that the theory is wrong for a priori reasons and will keep changing the subject until you get tired of arguing with him.
If you google him you'll see that he's done the same thing on many fora including this one several other times. It's really pretty useless to keep answering his questions as he's never going to stop and say "oh I get it now".
Somasimple, why don't you just explain your theory? (in the IR forum here) It may well be that you can explain the data as well as or better than the Hodgkin-Huxley model (and it's extensions). Why not let us judge your hypothesis in the only way hypotheses can be, by testing them with real data.
Until then, the fact remains that the Hodgkin-Huxley model is very very good at making testable predictions and works better than any other model we currently have. This alone is reason enough to think that the model is at least a good approximation to the truth.
  • #83
Cincinnatus,
The same answer may apply to you. Are you unable to describe the thing?
  • #84
And I got, every time, different explanations. :confused:
We are currently testing the initial conditions of this model and you refuse to explain the next mandatory step of its functionning. :confused:
Somasimple said:
Then,
Giving a good answer is the best way to smash me down!
Come on, it's my pleasure.
  • #85
It has everything to do with the current question. If you understood the principles I linked to then you would understand capacitors and how a membrane acts as one, as well as how a potential difference can be established by a chemical gradient. I take it then that you did not even bother to read what I provided.
IC:
Then,
I will restate my answer. The concentration of K+ increases until it reaches the equilibrium potential described by the http://en.wikipedia.org/wiki/Goldman_equation" across the membrane shows that it must carry equal and opposite charge density on each side. Obviously, since the charge carriers in this electrolyte are K+ and Cl-, the charges will be K+ on one side and Cl- on the other.
I hope the answer is sufficiently clear. If you have some specific question about one of the above physical principles, please don't hesitate to ask. If you merely have another rant about HH not being valid, please back it up with some experimental data that HH fails to explain and present your alternative which does explain it.
Your failure to understand HH and the underlying principles is not a valid criticism.
  • #86
For the lurkers following this thread, the Goldman equation which DaleSpam refers to in the previous post is the same as the equation we had been calling the GHK (Goldman-Hodgkin-Katz) equation earlier in this discussion. It is a variant of the Nernst equation which may be more familar to some people...
Anyway, somasimple doesn't seem to accept the GHK equation as applied to biological membranes...
  • Biology and Medical
  • Chemistry
  • Atomic and Condensed Matter
  • Electrical Engineering
