• Support PF! Buy your school textbooks, materials and every day products Here!
Adding 2 open sets
  • Thread starter estro
"Adding" 2 open sets
I'm trying to prove that If both S and T are open sets then S+T is open set as well.
[itex]S+T=\{s+t \| s \in S, t \in T\}[/itex]
S+T is open if every point [itex] x_0 \in S+T [/itex] is inner point.
Let [itex]x_0[/itex] be a point in S+T, so there is [itex]s_0[/itex] in S and [itex]t_0[/itex] in T so that [itex]x_0=s_0+t_0[/itex].
S is open so for every ||s-s_0|| < δ_1 s in S.
T is open so for every ||t-t_0|| < δ_2 t in T.
Let x be point in S([itex]x_0[/itex], _delta_), I will write x=s+t. [both s and t are some vectors in R^n]
s+t in S([itex]x_0[/itex], _delta_)={s+t | ||[itex]s+t-s_0-t_0[/itex]|| < _delta_} and here I stuck, if I could conclude from ||[itex]s+t-s_0-t_0[/itex]|| < _delta_ that ||[itex]s-s_0[/itex]|| < δ_1 and ||[itex]t-t_0[/itex]|| < δ_2 the proof will be over, however I just can't find the algebraic manipulation.
Will appreciate any help.
Thanks.
Answers and Replies
Still need help with this one...
3,277
Please don't bump after only 12 hours. Wait at least 24 hours.
Anyway. Take s in S fixed. Can you prove that s+T is open?
Sorry for being impatient.
When I try to prove that s_0+T is open I get into the same trouble:
s_0+T is open set if there is δ such that S(x_0=s_0+t_0, δ) in s_0+T, so let x_0 be point in S(x_0=s_0+t_0, δ) but from the definition: S(x=s_0+t_0, δ)={x | ||s_0+t_0-x||<δ}, in short I get into the same kind of trouble...
3,277
You can find a delta such that [itex]S(t_0,\delta)\subseteq T[/itex], since T is open.
Now, can you deduce that [itex]S(t_0+s_0,\delta)\subseteq s_0+T[/itex]??
I think I was able to prove that s_0+t is open:
Let x_0 be in s_0+T, so there is t_0 and s_0 such that s_0 in S and t in T.
S is open so there is δ_1 so that S(s_0, δ_1) in S, so if ||s-s_0||< δ_1 then s in S.
Let x be in S(s_0+t_0, δ_1)={x=s_0+t | ||s_0+t-s_0-t_0|| < δ_1, s_0 in S}={x=s_0+t | ||t-t_0|| < δ_1, s_0 in S}, now because ||t-t_-0||< δ_1 t is in T so S(s_0+t_0, δ_1) in s_0+T.
Is this ok?
Now trying to prove the more that S(t_0+s_0,_some_delta_) in S+T.
I think the above proof is wrong because with similar technique I can prove that S+T is open set even if only S {or T} are open:
Let [itex]x_0 \in S+T[/itex], so [itex]x_0=s_0+t_0[/itex] where [itex]s_0 \in S, t_0 \in T[/itex]
S is an open set so there is [itex]\delta_s>0[/itex] such that [itex]S(s_0,\delta_s) \subseteq S[/itex] so for every [itex]s \in S[/itex] that satisfies [itex]||s-s_0|| \leq \delta_s, s \in S[/itex]
Let [itex]x \in R^n[/itex], we can write it as [itex]x=t_0+s[/itex] where [itex]t_0 \in T, s \in R^n[/itex] then if [itex]x=t_0+s \in S(s_0+t_0, \delta_s)=\{t_0 + s | \|t_0+s-t_0-s_0\|< \delta_s, t_0 \in T\}=\{t_0+s | \|s-s_0\|< \delta_s, t_0 \in T\} \subseteq S+T[/itex] because [itex]t_0 \in T\ and\ s \in S[/itex]
Whats wrong?
Found my mistake.
micromass, thanks for your hint [got it at last]!
Related Threads for: Adding 2 open sets
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
