Solving for Unknown Vectors in Vector Addition Equations
In summary, the conversation discusses the addition of a third vector "c" to the existing vectors "a" and "b" in order to create a new unit-vector notation that results in a sum of zero. The solution involves finding a vector that, when added to the existing difference of "a" and "b", will result in a sum of zero. This can be done by changing the signs of the components of the existing difference vector.
queenspublic
59
"a" vector - "b" vector = 7m(i) + -3.5m(j) + -4.5m(k)
A third vector "c" vector pops out of nowhere.
Find the new unit-vector notation such that "a" vector - "b" vector + "c" vector = 0
?m(i) + ?m(j) + ?m(k)
a - b + c = 0
c = b - a? <<< How do you do it backwards?
You are given A-B, so they said they added another vector C...
So you have (A-B)+C=0, Since you already know A-B, you just have to find a vector that you can add to that which will sum up to zero.
remember i=x, j=y, k=z and you can only add x to x and y to x and z to z.
So its just basic math really. here is an example which should point you in the right direction.
<1,5> +<-1,-5>=<0,0>
Change the signs. Thanks NationalBasketballAssociationJamOneHundred!
What is the concept of adding vectors by components?
Adding vectors by components is a method used to find the resultant vector of two or more vectors by breaking them down into their x and y components and then adding them separately. This helps to simplify vector addition and makes it easier to understand and calculate.
How do you find the components of a vector?
To find the components of a vector, you can use trigonometric functions such as sine and cosine. The x component of a vector can be found by multiplying the magnitude of the vector by the cosine of the angle it makes with the x-axis. Similarly, the y component can be found by multiplying the magnitude by the sine of the angle.
What is the process of adding vectors by components?
The process of adding vectors by components involves breaking down each vector into its x and y components. Then, the components are added separately to find the resultant x and y components. Finally, the magnitude and direction of the resultant vector are found using the Pythagorean theorem and inverse trigonometric functions.
Why is adding vectors by components useful?
Adding vectors by components is useful because it allows for easier visualization and calculation of vector addition. It also helps to break down complex vectors into simpler components, making it easier to understand the relationship between different vectors.
What are some real-life applications of adding vectors by components?
Adding vectors by components is used in various fields of science and engineering, such as physics, mechanics, and navigation. It is also used in computer graphics to simulate movement and in sports to analyze the motion of athletes. In addition, it is used in geometric applications, such as finding the resultant force on an object in a system of forces.
