Adjoint of an adjoint?
  • Thread starter daniel_i_l
daniel_i_l
I have a general question about adjoints, does:
adj(adj(A)) = A?
Intuitivly it looks right and the examples that i tried worked out but is it always true?
Thanks.
Answers and Replies
Hurkyl
Staff Emeritus
What kind of object is A, and which definition of adjoint are you studying?
daniel_i_l
A is a nxn matrix and the definition that I'm using is the transpose of the cofactor matrix.
matt grime
9,420
That isn't the adjoint, that is the adjugate.
Adj(A) is the matrix that satisfies
A*Adj(A)=det(A)I
From this we see that (det(Adj(A))/det(A))*A is Adj(Adj(A)), when det(A) is non-zero. I leave it to you to determine what the det of Adj(A) is.
Hurkyl
Staff Emeritus
As I recall, one of the principal properties of the adjoint is
A * adj(A) = det(A) * I​
which should allow you to easily settle your question, at least for invertible matrices.
(P.S. I too have heard this called the adjoint before)
daniel_i_l
matt grime: The det of adj(A) is det(A)^n-1 if A is invertible. So that means that adj(adj(A)) = det(A)^n-2 * A =/= A. But what happens is A is singular?
Hurkyl: As i said above, this would mean that it isn't true for invertible matrices but what about the singular ones?
Thanks!
Hurkyl
Staff Emeritus
If you just want a specific example, there's the zero matrix.
daniel_i_l
That would be a case where it is true, is there a case where it isn't true?
Thanks.
Hurkyl
Staff Emeritus
You haven't proven they're unequal. In fact, you said yourself you know of examples where they are equal.
Hurkyl
Staff Emeritus
Thanks.
Well, have you really tried many examples? The formula you derived suggests that most matrices do not satisfy the given equation... so the fact that you did not find a counterexample suggests that you really haven't tried much!
daniel_i_l
Well, they're only equal when det(A) = 1 and when A is invertible, not in general, right?
Thanks.
Hurkyl
Staff Emeritus
Thanks.
You have shown that, if you assume A is invertible, then they're equal iff det(A)^(n-2) = 1.
In particular, it says nothing about the noninvertible case, and you missed some cases in the invertible case.
Wait, is your arithmetic right? Shouldn't that be det(A)^(2n-2)?
daniel_i_l
What invertible cases did I miss? And how do I approach the non-invertible cases?
And I think that the arithmetic is right:
|adjA|/|A| = |A|^(n-1) / |A| = |A|^(n-1-1) = |A|^(n-2)
Thanks!
matt grime
9,420
In the non-invetible cases, there are differences depending on what the rank of A. It is easy to find cases where Adj(A) is the zero matrix. As Hurkyl has said, the number of cases where youir conjecture is true is vanishingly small, so you really can't have tried that many cases.
Hurkyl
Staff Emeritus
How did you deduce det(A) = 1? Is that something you're always allowed to do?
daniel_i_l
Your're right:) My problem was that I only tried 2x2 matrices, but for this invertable 3x3 matrix:
[1 0 0]
[0 1 0]
[0 0 2]
The equation isn't true. and for the non-invertable matrix where all the numbers are 1 it also isn't true.
matt grime
9,420
It isn't true for many 2x2 matrices either.
Suggested for: Adjoint of an adjoint?
  • Last Post
  • Last Post
  • Last Post
12K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
