Homework Help: Adjustable Voltage Regulator
  1. Nov 8, 2009 #1
    Hi Everyone,
    I need to design an adjustable voltage regulator without using an IC. Does anybody could give me a source that can help me?
    Input will vary between 10-15 volts... And output will be adjustable between 4-6 volts.
    Line and Load regulations must be around %1
    Need your help...
    2. Relevant equations
    3. The attempt at a solution
  3. Nov 9, 2009 #2
    berkeman
    Staff: Mentor
    Welcome to the PF. The easiest way to start would be to look at the equivalent circuit in the LM317 datasheet. That will show you how that adjustable linear voltage regulator IC is put together, and you can do something similar using discrete transistors, etc.
