Homework Help: Advice on circuit diagram
  1. Dec 26, 2017 #1
    a) the equivalent single Δ-connected load
    I have uploaded circuit
    2. Relevant equations
    none yet
    3. The attempt at a solution
    I am not sure if the question is asking me to find the resistance of both delta and y connected loads then work out them both in parallel. After I have the answer find a delta load for a circuit that equals this or simply find the delta loads impedance. That seems a bit easy from what i have done on my last question.
    The questions after the question number a make me think i should do it the first way i said but i am a bit unsure.
    also question b says i need to transform delta to y in question a but i dont see why.
    Any advice please
  3. Dec 26, 2017 #2
    Baluncore
    Note that the loads are complex.
    Approach load summation from the Δ side.
    3a. Transform the Y load to a Δ, then sum the two parallel Δs into a single Δ load.
    3b. Transform that parallel sum Δ from 3a, into a single Y load.
    Now approach load summation from the Y side.
    3c. Transform the Δ load of fig 3, to a Y, then sum it in parallel with the existing Y load to make one Y load.
    3d. Find the real power dissipated in the complex Δ load.
    So you can see that it does not matter how you approach the result. The Yb solution should be the same as the Yc solution.
Have something to add?
Draft saved Draft deleted
