Aerodynamics and Flight Mechanics
In summary, aerodynamics is the study of the forces that act on objects as they move through air. It affects flight by determining the lift, drag, and stability of an aircraft. Lift is created by the difference in air pressure above and below the wings of an aircraft, while drag is the resistance caused by the air. Pilots use their understanding of aerodynamics to control and maneuver the aircraft during flight.
EngTechno
72
What is the difference between Aerodynamics and Flight Mechanics?
aerodynamics studies the properties of moving air. on an airplane, this creates forces (lift and drag) and torques. Flight dynamics looks at what these forces do with your airplane (how does it move?). Also thrust and gravity are of course included with flight mechanics. They have nothing to do with aerodynamics.
actually they have EVERTHING to do with aerodynamics.. without thrust u can't generate lift, without gravity u can't provide unaided lift... but they ARE 2 sepearate fields.. and you are correct.. just wanted to clear that up a bit.
1. What is aerodynamics?
Aerodynamics is the study of how objects move through air and the forces that act upon them. It involves the principles of fluid mechanics, including the interaction between an object and the air around it.
2. How does aerodynamics affect flight?
Aerodynamics plays a crucial role in flight as it determines the lift, drag, and stability of an aircraft. The shape and design of an aircraft, as well as the airspeed and angle of attack, all affect its aerodynamic performance.
3. What is lift and how is it created?
Lift is the force that keeps an aircraft in the air. It is created by the difference in air pressure above and below the wings of the aircraft. As air flows over the curved shape of the wings, it creates a higher pressure below the wing and a lower pressure above, resulting in an upward force.
4. What is the difference between drag and thrust?
Drag is the force that opposes the motion of an aircraft and is caused by the resistance of the air. It is affected by the shape and size of the aircraft, as well as its speed. On the other hand, thrust is the force that propels an aircraft forward, usually generated by the engines.
5. How do pilots use aerodynamics in flight?
Pilots use their knowledge of aerodynamics to control and maneuver the aircraft. They adjust the angle of the aircraft's wings, the speed, and other factors to maintain lift, overcome drag, and achieve the desired direction and altitude of the flight.
  • Aerospace Engineering
  • General Discussion
