How do aerodynamic features improve the performance of sportscars?
In summary: Aero Publishers has three books on automotive aerodynamics. "Engineer to Win", "Prepare to Win", and "Tune to Win". "Tune to Win" is an introductory class on external aerodynamics. "Frontal Area", "Coefficient of Drag", "Shape", and "Parasite Drag" are discussed. "Drag HP", "Drag Coeff.", "Frontal Area", "Coefficient of Drag", and "Shape" are translated into horsepower required to overcome drag. "Parasite Drag" is discussed, and "Hex head bolt C.D.", "round head bolt C.D.", "brazier pop rivet head C.D.", "countersunk machine
tormund
can anyone enlighten me with key aerodynamic features which are used to heighten the performance of sportscars.
thnx:approve:
glad to
you talking about real race cars or door slammers?
no, talking more along the lines of ferrari, lamborghini, porsche, bugatti, etc. More the type of car that you really want to drive, but at the same time don't want to because its too nice
There's no such thing as a car that's too nice to want to drive. :biggrin:
I agree..ifin you can't afford to see it come back on the hook don't race it..
I never liek to see the tow truck with the car dangling from it..but it happens, not a case of if..but when..cause it will happen...
Read the following 3 books published by Aero Publishers and written by Carroll Smith
Engineer to Win, Prepare to Win, and Tune to Win
also TV Motorsports published a good book , Inside Racing Technology by Paul Haney and Jeff Braun
Tune to Win gives the best basic introductory class on External Aerodynamics..
bottom line is any serious racer ( going over 100 mph) had better be aware of what it is and how it effects the car)
At road speed over 100 mph, aerodynamic drag is the most important limiting factor I straight line performance.
basic formula for automotive drag is
Drag (lbs.) = Drag Coeff. X (surface area in feet² ) X (velocity in mph)² / 391
unfortunately this number don't mean much so we have to translate pounds of drag into Horsepower required to over come it so we can better understand what we are facing..
Drag HP = Cd x Frontal Area x Velocity ³ / 146,600
the second factor of Aero is to channel the air to provide more downforce to better stick the tires..see previous posts from me titled Race Car Physics..it is all about tires..in fact, Indy cars theoretically have enough down force to literally stick to the ceiling at speed..
more on this later
Frontal Area..pretty much fixed when car is designed..less is better but tire track width will ultimately determine the square footage
Coefficient of Drag- most team effort is to reduce this..again..designer sets this unless you are super good with fiberglass or carbon fiber and own a wind tunnel
Shape- myth buster...hypersonic aerodynamics and high speed shapes are not for us!
That stuff deals with compressible flow..no interest to us..we need large radiuses and gentle transitions. remember that these cars, especially mid engine types , don't like low drag shapes like the classic tear drop...not real practical..so the particle shape the car ends up with is going to generate some degree of aero lift. .this lift has to be compensated for with drag producing down force generators to cancel out the lift and add more down force.
in order to deal wit lift we need hi pressure area to form beneath the car and we have to prevent a low pressure area on the top of the vehicle.
one thing we have to eliminate as much as possible is letting any air flow UNDER the car
secondly..facing the fact that the top of the doorslammer is going to have air flow, nothing we can do about it..it is mandatory that this flow not separate..when this happens..we get low pressure and this makes lift.
more later
Parasite Drag- took a long while but racers finally figured out but now they attack small increments of parasitic drag as fanatically as weight..i.e.. scrimping on grams to add up to pounds..drag caused by bumps, joints , protrusions all contribute to drag..an exposed bolt head on the needle nose of a FC car will produce tiny amount of drag..AND more important, flow will separate at the object and turbulence wake produced will propagate at the standard 20 degrees included angle until it reattaches ..if it does.
Hex head bolt C.d. = 0.80
round head bolt C.d. = 0.32
brazier pop rivet head C.d. = 0.04
countersunk machine screw C.d. = 0.02
flush countersunk rivet C.d. = .002
most critical areas to look for drag is forward 1/3 of the body plus the forward 30% and all of the underside of the wing.
trick is to delay flow separation to a point as far aft as possible
next aero down force
study Bernoullis theorem ..this is the main principle involved.
race car wings function like propeller aircraft wings wit ha few differences
it is mounted " up side down" to produce down force instead of lift
is must operate both close to the ground and in dirty air...air disturbed by the vehicles passage through it and in close proximity to the ground
rules prohibit changing attack angle of the wing must be fixed in one position
there is a lot of engineering that goes into a successful wing design. Attack angle, Stall. Aspect ratio ( span/chord) Lift to Drag Ration , center of Lift
too much to go into detail here but the bottom line is you have to balance downforce with Drag. Another thing to consider is if you add downforce, you will have to change springs. ride height will change and you may risk bottoming out.
Another trick we use is a full bellypan sealing up the underside of the car and we add a diffuser to this in order to channel the air out and make more down force. It is basically a fiberglass tunnel to increase air speed under the car ( thus low pressure)
it is one of the compromises we have to make considering we can not prevent air from entering the area between the bottom of the car and the track...
these two things are a science in them selves and are the major components to adding down force to the car, once the car is made a smooth and slick as possible.
unless there is a question..i will leave this topic as it is
1. What is aerodynamics and why is it important for sportscars?
Aerodynamics is the study of how air moves around objects and how it affects the object's motion. In sportscars, aerodynamics is important because it directly impacts the car's speed, handling, and fuel efficiency. By designing a car with good aerodynamics, it can achieve higher speeds and have better stability on the road.
2. How does the shape of a sportscar affect its aerodynamics?
The shape of a sportscar plays a crucial role in its aerodynamics. A sleek and streamlined shape with minimal drag, such as a teardrop shape, allows the car to move through the air more efficiently. This reduces the resistance and allows the car to achieve higher speeds. Additionally, a well-designed shape can also create downforce, which helps keep the car stable at high speeds.
3. How are spoilers and air dams used in sportscars for aerodynamics?
Spoilers and air dams are used to manipulate the airflow around a sportscar for better aerodynamics. Spoilers, which are usually located on the rear of the car, create downforce to keep the car stable at high speeds. Air dams, on the other hand, are located on the front of the car and help to reduce the amount of air flowing under the car, reducing lift and improving stability.
4. Can the weight of a sportscar affect its aerodynamics?
Yes, the weight of a sportscar can have a significant impact on its aerodynamics. A heavier car will have more resistance and require more power to move through the air, reducing its speed and efficiency. On the other hand, a lighter car will be more aerodynamic and require less power to achieve the same speeds.
5. How do wind tunnel tests help improve the aerodynamics of sportscars?
Wind tunnel tests are essential for improving the aerodynamics of sportscars. By simulating the airflow around the car, engineers can identify areas of high drag and make adjustments to improve the car's aerodynamics. These tests also allow for the optimization of spoilers, air dams, and other aerodynamic features to improve the car's performance on the road.
