Homework Help: Age of a meteorite
  1. Sep 1, 2015 #1
    Rectifier
    The problem statement
    The ratio between stable Argon atoms(##^{40}Ar##) and radioactive Potassium atoms(##
    ^{40}K##)in a meteorite is 10.3. Assume that these Ar atoms are produced by decay of Potassium-atoms, whose half-life is ## 1.25 \cdot 10^9 ## years. How old is the meteorite?
    Translated from Swedish.
    The attempt at a solution
    Radiactive decay can be calculated with ## N(t) = N_0e^{- \lambda t}## where t is time and lambda is constant. Half-life gives us ## \frac{1}{2} = N_0e^{- \lambda t}##
    And we know that
    ## \frac{N_{r}}{N_s}=10.3 ## and ##N_{r} + N_s = N_0## thus ##N_r = \frac{N_0}{11.3} ##
    ## N(t) = N_0e^{- \lambda t}## and ##N_r = \frac{N_0}{11.3} ## give us ##\frac{N_0}{11.3} = N_0e^{- \lambda t}## and ## t=4.3 \cdot 10^9 ## which is wrong :/.
    Can someone help please?
  3. Sep 1, 2015 #2
    DrClaude
    Staff: Mentor
    The way I read it, there is 10.3 times more argon than potassium, not the other way around.
  4. Sep 1, 2015 #3
    Rectifier
    Tanks for the reply!
    So it should be:
    ## \frac{N_{s}}{N_r}=10.3 ## and ##N_{s} + N_r = N_0## thus ##N_r = \frac{N_0}{11.3} ##
    and I get the same answer :D
  5. Sep 1, 2015 #4
    DrClaude
    Staff: Mentor
    I didn't notice that you had made a second error cancelling the first one!
    I notice now that
    is not correct.
    What is the value of ##\lambda##?
  6. Sep 1, 2015 #5
    Rectifier
    Is it ## \lambda = \frac{ln2}{T_{1/2}}## ?
    EDIT:
    Thus ## \lambda = \frac{ln2}{T_{1/2}} =\frac{ln2}{1.25 \cdot 10^9 } ##
  7. Sep 1, 2015 #6
    DrClaude
    Staff: Mentor
    That's correct.
    I made the calculation myself, and find the same value as you. Why do say the answer is wrong?
  8. Sep 1, 2015 #7
    Rectifier
    My teacher told me so. Well I guess that he is wrong then.
  9. Sep 1, 2015 #8
    DrClaude
    Staff: Mentor
    Didn't he give any hint as to what was wrong?
    The only thing I can see is that your answer does not have the correct number of significant digits.
  10. Sep 1, 2015 #9
    Rectifier
    Ah sh*t :D
    "Svara med två decimaler"
    Then its 4.37 :D
  11. Sep 1, 2015 #10
    DrClaude
    Staff: Mentor
    Precis!
    You could also infer it from the fact that both the ratio and the half-life are given with three significant digits.
  12. Sep 1, 2015 #11
    Rectifier
    Thank you for your help!
Have something to add?
Draft saved Draft deleted
