spinnaker
- 23
We know the terrestrial planets formed by aggregation of debris from the solar nebula. We want
to calculate the maximum size of object that can form by aggregation before self-gravity causes it to pull itself into a round shape.
Our analysis is assisted by considering Earth’s mountains. It is clear from Earth’s geology that of its many mountains, none are taller than 10 km high. This indicates that the strength of rock at the center of the base of a mountain cannot support a structure higher than 10 km. The pressure at the middle of the base of a mountain is equal to the weight of a column of rock (with unit cross sectional area) as high as the mountain. If a mountain were taller than 10 km, it would slump or begin to be overtaken by self-gravity. We want to use this fact to determine the maximum size of an object that can form without being overtaken by self-gravity.
Assume you have two cubes of rock (density of 3000 kg/m3) of equal mass (M) and size (length d) that are face to face. They are so large that the only force holding them together is pressure caused by gravitational attraction, but not so large that they flow into a spherical shape due to self-gravity.
Determine the maximum size of rectangular body that could be made from the two cubes.
Force between cubes is F = GM2/d2
V = d3
M = ρV = ρd3
F = GM2/d2 = Gρ2d4
I think I have the formulas okay, but I don't know how to get a "maximum" size out of the equation.
