AgNO3 + NH3?
  • Thread starter Kitty808
Ok, lab work...
I have to figure out a way to separate out the individual cations from a solution containing Fe(NO3)2, Cr(NO3)2, Ag(NO3), and Ni(NO3)2 and get each one into a particular form and perform a confirmatory test on it.
I've think I know how to get started on it. First adding some NH3 to the solution I should have Ni(NH3)6(2+) (aq), Fe(OH)3(s), Cr(OH)3(s), and Ag(NH3)2(s). Centrifuging out the solid should leave the Ni(NH3)6(2+) which I can run the confirmatory test on.
This is where I get a little stuck. I think by adding NaOH to the solids I should get Fe(OH)3(s), Cr(OH)4(-1)(aq), and Ag(OH)(aq)? I'm not sure about the Ag(OH) if that is correct and whether it is aq or s.
If I did my reaction right its:
Ag(NH3)2(+) + NaOH --> Ag(OH) + Na(NH3)?
If I could get some input as to whether I'm on the right track or not it would be appreciated very much.
Answers and Replies
Borek
Mentor
28,530
2,962
I would separate Ag+ as chloride. Ag(NH3)2+ is not a solid.
But it seems like you are contradicting yourself in your post.
46
Ok, lab work...
Maybe you intended [tex]Fe(NO_3)_3,\ Cr(NO_3)_3? [/tex] Otherwise they can't then give [tex]Fe(OH)_3,\ Cr(OH)_3[/tex] as you write after
And [tex]Ag(NH_3)_2^+[/tex], as Borek wrote.
No.
[tex]2Ag(NH_3)_2^+\ +\ 2NaOH\ \rightarrow\ Ag_2O\ +\ 2Na^+\ +\ 4NH_3\ +\ H_2O[/tex]
(Initially it forms AgOH, which quickly decomposes into the oxide).
Anyway, adding OH- to an ammonia solution of silver can produce dangerous compounds, so it's not advisable.
Borek,
First off I am into learning on my own, but I am stuck here and could use a little help.
I am working on equation writing, I have NH3(aq) + AgNO3. I have hit the Raymond Chang, Ninth edition for explanation on solving this, but I might be in the wrong section for comprehension. Could you guide me in the direction of information that could help me solve this, Thanks.
Borek
Mentor
28,530
2,962
Go net ionic. Ag+ is getting complexed by two ammonia molecules.
Please don't necropost, rather start a new thread.
Will do, thanks.
Related Threads on AgNO3 + NH3?
  • Last Post
  • Last Post
  • Last Post
  • Last Post
10K
  • Last Post
17K
  • Last Post
  • Last Post
