• Support PF! Buy your school textbooks, materials and every day products Here!
Air flow meter
  • Thread starter RApak
i am trying to make an air flow meter using an heating element which i got from an iron..basically i have thought of inserting the element into a duct through which i will pass air using a blower,to connect the element with a 12v supply in series with a ammeter...thn i ahve planned to scale the amount of air flowing with respect to the cahnges in current tht it produces.i am not sure if i will suceed with this idea..i would like to know what others tink about it
Answers and Replies
252
You mean to measure the changes in resistance due to self heating? I don't think that will be very accurate. I'd think you'll need an upstream and a downstream thermometer.
I hope this is an 110V heating element, that you run with such a low voltage that the temparature can't get dangerously high? Even at only 1% a heating element without attached iron can get quite hot already.
i just want to measure the air flow using the element..if i apply 12 volts across it and let air flow across it it would cool down and the resistance would change causing the current to change right??..i have to further convert the current to voltage so that i can use a micro controller ahead..if u have any other ideas of how to make an air flow meter plz do post them
Related Threads on Air flow meter
  • Last Post
  • Last Post
  • Last Post
  • Last Post
22K
  • Last Post
  • Last Post
