Air gap in toroid
(I have done parts i) through v) correctly. It is the remaining two I'm stuck on.
A toroid of rectangular cross-section has a height of 10mm, an inner diameter of 68mm and an outer diameter of 82mm. It is made of iron and is wound with 118 closely-spaced turns. When a current of 2A flows, calculate;
i)the mmf around the toroid
ii)the magnetic field-strength within the toroid
iii)Using B-H curve determine the flux density and flux in the ring,
iv)the relative permeability at this point on the curve
A 1mm air gap is then cut in the toroid. The current is still 2A. Calculate;
v)the new flux density in the ring,
vi)the mmf around the ring, and across the air gap.
vii) It is then required to establish a flux density of 0.75T in the air gap. Calculate the current needed to do this.
Answers to parts vi) and vii)
vi) 53, 183 A-t
vii) 8.0 A
[tex]m.m.f.=NI=BS(R_{m}iron+R_{m}air)[/tex]
[tex]R_{m}=\frac{l}{\mu_{0}\mu_{r}S}[/tex]
where
[tex]\mu_{r}=557[/tex],
I have [tex]B=0.21T[/tex] (although the answer gives it as 0.23)
[tex]R_{m}(iron)=4.787*10^6[/tex] and [tex]R_{m}(air)=11.365*10^6[/tex]
[tex]S [/tex]= cross-sectional area = [tex]7*10^{-5}[/tex]
I get the m.m.f. across the air gap correct if I use the value of B = 0.23T in answers. My answer was 0.21T and I found this was significant:
[tex]R_{m}(air)=\frac{l}{\mu_{0}S}[/tex]
[tex]m.m.f.=BS(R_{m}(air))[/tex]
[tex]=0.23*7*10^-5*11.365*10^6=183.5At[/tex]
I did as before with the iron, subtracting the 1mm from \piD for l (in metres)
[tex]m.m.f.=BS(R_{m}(iron)[/tex] where
[tex]R_{m}(iron)=\frac{l}{\mu_{0}\mu_{r}S}[/tex]
but I get 70, which is far from the answer of 53.
For the last part (vii) I don't know why it isn't simply
[tex]I=\frac{BS}{N}R_{m}(air)[/tex]
with this I get 5A rather than 8
Your help is much appreciated.
Answers and Replies
Related Threads on Air gap in toroid
11K
  • Last Post
  • Last Post
40K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
