will6131
- 2
I have been thinking about the large number of "cold air intakes" and why they are such an overwhelming trend. I question their validity for a couple of reasons. First, the stock airbox on all new cars brings cold air in, usually from the fender, and is sealed off from the engine bay, usually better than the "cold air intake." This is especially seen on trucks, where a heat shield is all that is separating the filter from the engine bay on most "cold air intakes." Secondly, on many old musclecars and hot rods, both those built today and in the past, a simple open air cleaner is all that is used, and these engines make tons of power and torque. These people are not bound by anything (cost, noise, etc ) and would most likely make the intake work as well as possible, at least in most instances. Granted, looks may be a factor in some cases.
I am assuming that what we are really interested in is the mass flow rate (or, mass air flow) of the intake. Assuming pressure to be a constant (i.e. no forced induction or nitrous), and air being an ideal gas, we can then say
mass flow rate = ((air velocity)(area of intake opening))/temperature
this equation shows, if you can improve the area significantly, (which is easy to do over the stock setup) temperature can increase and mass flow rate will still increase. For example, with mine, I increased my area by a factor of 48 while increasing my temp by a factor of 1.4
However, I don't know how to determine the velocity change. I simply opened up my stock intake to the filter (i.e. removed the air box surrounding it).
My overall hypothesis is that "cold air intakes" work not by giving you cold air, but by giving you more air, and the reason stock intakes are less efficient is noise reduction only.
