Airplane Landing Questions -- How can the pilot see the ground?
In summary, the process of landing an airplane involves slowing down, lowering the landing gear and flaps, and lining up with the runway. In good weather, pilots use visual indicators while in bad weather they rely on electronic glide slopes. All airplanes, regardless of size, follow the same slope during landing. In modern airplanes, pilots can see the runway ahead, but this was not always the case in older airplanes. Commercial airliners have an altitude call out system for the final approach, using a radar altimeter to measure the height above the runway. In some situations, such as at certain airports, smaller aircraft may use a steeper slope to avoid wake turbulence from larger aircraft. Emergency takeoffs during landings are known as go-arounds,
  • #36
seazal said:
Please suggest books that answer these questions directly:
Before the Wright Brothers, what were the theories why birds fly? When was the airfoil technology or principles first discovered? And why were the Wright Brothers the first one to successfully apply it?
To study early understanding of bird flight search for biographies of Leonardo d'Vinci. Leonardo's sketches of birds were used for centuries. His drawings include many sketches of possible and impossible vehicles. The painter James Audubon continued the tradition of accurate images of birds. Please choose yourself from the many books on both painters.
Though generally associated with hot air balloons, the Montgolfier brothers studied flight before the Wrights. https://en.wikipedia.org/wiki/Montgolfier_brothers
This beginning aerodynamics tutorial is a starting point for NASA docs. https://www.grc.nasa.gov/www/k-12/airplane/bga.html
  • #37
The Wright brothers were successful for many reasons but IMO their design of a light-weight piston engine fueled by gasoline gave them just enough power-to-weight to enable controlled powered flight. As previously mentioned they also built scale-model wind tunnels to test designs. Their experience as bicycle mechanics helped design the fuselage and (later addition) undercarriage.
  • #38
jim hardy said:
You've probably felt but were unaware of something called "Ground Effect"
when the plane gets about one wingspan above the ground, the air underneath it has to get squished out from under the wings
raising pressure on bottom side of the wings causing more lift.
Pilot will reduce power and raise the nose to increase drag and dump speed, encouraging the plane to continue on down to the ground..
https://en.wikipedia.org/wiki/Ground_effect_(aerodynamics)
Next time you fly
pick a window seat a row or two behind back edge of the wing.
Pay attention to what goes on as you get over the end of the runway-
As the plane descends toward the runway you'll see those big flaps move back and down changing the wing shape from flat to curved
trapping air underneath the wing as it gets ever closer to the runway.
On a warm humid summer day you'll see vapor trails curl around the flap edges as the air moves from high pressure region ahead of the flap to low pressure behind it, cooling as it goes...
Just watch and ask yourself "why" about everything you notice.He looks out the side window.
Jim. Why did you say "He looks out the side window" when I asked how the pilots can see landing strip with nose pointed up? I found out they could actually see the runaway. Check this out.
https://www.google.com/search?q=pilot's+view+landing+an+airplane&ie=utf-8&oe=utf-8&client=firefox-b-1
Yesterday I was surprised learning the pilots could still see the ground during landing. Is it not the nose is pointed upwards so the pilots shouldn't see the ground. I guessed prior to learning it they were all landing blind. But are there airplanes where they really land blind?
If you like aviation
i recommend reading Charles Lindbergh's "Spirit of St Louis"
he didn't have a forward view at all , only side windows...
the 1956 movie staring James Stewart is also very good, and is on Netflix
  • #39
seazal said:
But is it illegal?
Maybe not illegal (?) ... but you would need to have a damn good reason.
Lol... and an even better story. . :oldwink:
  • #40
seazal said:
I guessed prior they were all landing blind. But are there airplanes where they really land blind?
of course it depends on how the front of the plane is shaped
and if it's tricycle gear or taildragger
https://studentpilotnews.com/2017/06/09/video-pilots-eye-view-p-51-flight/
  • #41
Jump to 50 seconds of this video
You can see cracks forming in the fuselage (why does the crack formed and how often does it happen?) and the plane breaking apart in midair, so the passengers just fall down from the sky. If one wears a parachute, perhaps one can survive the fall?
  • #42
russ_watters said:
Mars, it would take a very large and light airplane.
Or just a lot of speed. NASA has considered the use of gliders going fast enough for a reasonable glide ratio and duration of time before crashing to surveil the surface of Mars. Various prototypes have been tested by dropping them from weather balloons at high altitudes. Most of the gliders are autonomous, but switch to radio control like mode for controlled landings. Example article:
https://www.nasa.gov/centers/armstrong/features/whaatrr_glider.html
Likes russ_watters
  • #43
What units do you measure the density of air on earth? And can anyone share any calculations to support that airfoil principle is enough to lift millions of pounds (3.3 million pounds in case of the space shuttle)? It's somewhat hard to believe that mere air and even air pressure can support such weight. It looks like as thrust increases, the pressure increases. What formulas relate them.
  • #44
Klystron said:
The term autopilot seems slightly naive on an I-level thread.
I disagree. Even in modern fighters, there are modes in the flight control that are called "autopilot modes".
  • #45
Yes. It is noticeable if you pay close attention. It feels as though the plane slides forward a little faster just as it is about to touch down.
Likes Klystron
  • #46
https://www.tsa.gov/travel/security-screening/whatcanibring/items/parachutes
You may transport parachutes, either with or without Automatic Activation Devices, in carry-on or checked bags.
Parachutes should always be packed separately from other baggage. If a TSA officer determines that a bag must be opened to inspect the parachute, you must be present to assist in the inspection. If you are not within the screening area, you will be paged using the airport intercom system; if you are not present to assist with screening the parachute, the parachute will not be allowed on the plane. For this reason, passengers with parachutes are encouraged to add 30 minutes to the airlines' recommended arrival window. TSA is not responsible for repacking parachutes. All parachutes should be thoroughly inspected at their end destination to make sure that the equipment is still safe to use.
  • #47
In case it's not obvious that bit of the video is cgi. Aircraft almost never break up that slowly. They are pressurised so the forces on an area of a few square feet is very high. Think explosion not slow break up.
In an earlier post I listed several reasons why having a parachute is not likely to help. I could easily afford to buy one but taking one on a civilian airliner is a total waste of time.
  • #48
You can see cracks forming in the fuselage (why does the crack formed and how often does it happen?)...
https://en.wikipedia.org/wiki/China_Airlines_Flight_611#Metal_fatigue_cracking
It was an improper repair from a previous incident that weakened the tail. It's not a common thing.
...and the plane breaking apart in midair, so the passengers just fall down from the sky. If one wears a parachute, perhaps one can survive the fall?
If they are already wearing the parachute and if the breakup of the plane doesn't kill them and if they are able to get out of whatever piece of the plane they are trapped in. If, if, if, if, if.
Of course, if they are in a crash on the ground, wearing the parachute could make it harder to escape the burning plane, making death more likely.
Likes jim hardy
  • #49
I'm starting to wonder if you are really serious here or are just messing with us - pretending to be panicky and irrational. Surely you know the Space Shuttle flies into space over a cluster of rocket engines, not from aerodynamic lift, right?
This thread needs to become more serious, rapidly, or it will be closed.
Likes jim hardy and Klystron
  • #50
Air pressure can exert a huge force -- much more than required to hold up an airplane. A modern fighter easily performs maneuvers at G's up to 9. That is 9 times more than required to hold the plane up and it is all coming from air pressure. All that is needed from an engine to keep a plane up is enough thrust to stop the downward glide of the plane. That is not much.
Likes russ_watters
  • #51
Any airplane mishap is investigated like crazy. It's not like with car accidents, where they only pay attention after dozens or hundreds of crashes. Any crash will be investigated thoroughly for months or years if necessary. The only reason that is practical is that there are so few accidents.
Likes russ_watters and Klystron
  • #52
Yes. My intended point was that autopilot functions can be modeled by distributed systems; modes of operation across a flight control grid connecting cluster . Not as a monolithic "on/off" device.
  • #53
Stick your hand out the window of a car. Drive into a headwind at highway speed. Note the pressure when your hand is aligned with the airflow, and when your hand is perpendicular to the airflow. Compare the area of your hand to the area of a wing. Consider that aerodynamic forces are proportional to the square of the airspeed. Consider that your hand is not an airfoil.
Go to your nearest airport and pay for an introductory flying lesson. If it's in a single engine Cessna, ask for permission to open the window and stick your hand out. Single engine Cessna airplanes are allowed to fly with a window open, although it does get noisy.
  • #54
  • #55
It exploded at 35,000 feet and about 25 miles from nearest land. Even if you survived the explosion you would also have needed ..
Previous lessons in how to free fall.
An oxygen system.
A boat.
A waterproof GPS.
A waterproof satellite phone.
Or an emergency locator beacon.
  • #56
That China plane suffered a tail strike , that's where the tail drags the ground from a bad landing or takeoff.
PPRuNE talked about a 68 inch crack in underside of tail that was just patched over , might have failed depressurizing part of the plane and blew out a bulkhead.
I think that's what the official report concluded .
But i haven't read that report, just the thread at PPRuNE which is unofficial yet educational
Likes CWatters
  • #57
I was talking about the Space Shuttle landing, not take off. Remember it lands like an airplane and takes off like a rocket.
I'm serious because whenever I fly 2 hours short trips I always give reminders to family of important matters like codes to the safe, etc. just in case. And next year I plan to take longer flight (maybe 10 hours) to Europe I hadn't tried before. So just want to gain more knowledge of it (it is said that to treat phobia, you need to face the fear or study it more).
An airplane depends on continuous thrust or it could stall and fall down, whereas all other vehicles like cars or boats can be stop anytime and you are safely at ground.
I'm now convinced parachute is not needed because of difficulty of deployment. So just need to trust the best airliner. There is now this Airbus 380-800 model which has two levels. It needs much more thrust and jet engine, so the question now is.. is it better to fly using smaller airplane that requires smaller or fewer jet engine or bigger airliner with jumbo jet engines. Which do you prefer guys?
  • #58
If it lost total power, it would start gliding. It has a lot of time to get power again (except right at takeoff). Most commercial airplanes have several engines and can fly with fewer. The danger occurrences are few and far between. In fact, they are so rare that there will often be a TV show about any airplane crash like you are talking about. (Private airplanes are a different story. Those people are sometimes careless.)
  • #59
If the power won't come back. What model of airliners can actually glide all the way to ground? I watched this at movie once. This would be the safest?
I often ride budget airliner with only 1 engine at either side. So 2 engines at either side is better? What is the safest airliner model with many redundancies?
  • #60
The airlines select aircraft to fly routes based on many factors -- expected number of passengers, expected cargo, amount of fuel required to fulfill the route, available craft at origin airport, etc. One can choose which airline to book even select which flight to book based on the expected airframe but ultimately route fulfillment lies with the airline.
Suggestions:
  1. Install a decent flight simulator on a computer. (select software based on your platform +cost).
  2. Take public tours of flight related operations including air shows, air fields, air traffic control centers, open houses; most free.
  3. Visit air & space museums. Engage the docents.
Likes russ_watters
  • #61
They can all glide all the way to the ground (or water) Hahahaha! I crack myself up.
One engine is all they need. Remember that they only need enough power to push it from a shallow glide to level flight. Turns would need to be slow and wide.
Certainly, more engines improve safety, but two engines would improve safety so much that having more is not that much better.
Likes Klystron
  • #62
seazal said:
I'm serious...
Then you need to start being serious. You are saying way too much that is factually wrong or irrational. Being scared is fairly normal, but you're not in a plane, you're sitting behind a computer. You have time to think and not be scared.
I was talking about the Space Shuttle landing, not take off. Remember it lands like an airplane and takes off like a rocket...
An airplane depends on continuous thrust or it could stall and fall down...
1. The space shuttle's landing weight is 230,000 lb, not 3.3 million lb. That's closer to its takeoff weight.
2. The space shuttle lands without power; it glides.
If this fear is something that is causing you real problems, you should see a psychologist about it. All we can do here is correct your false beliefs of facts.
Technically, stalling can happen with or without thrust, but in either case, all airplanes carry spare engines so they can fly just fine if one fails.
Theoretically a plane with more engines should be safer in case of engine failure since it carries more extra engines, but from a practical standpoint airplanes are so safe I don't think that's been proven.
Likes seazal and Klystron
  • #63
Suggestions:
  1. Install a decent flight simulator on a computer and learn to fly and land the sim properly (select software based on your platform +cost).
  2. Take public tours of flight related operations including air shows, air fields, air traffic control centers, NASA installations; most free.
What is the best flight simulator PC software available now that is accurate and doesn't require you to spend months learning the flight manual? Just want to have a feel of landing and the software should be accurate, not just for gaming.
  • #64
https://www.x-plane.com/
I believe you can install and use a working trial version of it...for 15 minutes of flight at a time.
Likes seazal
  • #65
More knowledge is good, but there is a limit to the benefit. A serious fear of flying is like other phobias -- logic doesn't help a lot. I have a fear of spiders and will have to live with it forever. You may just have to resign yourself to accepting the dangers that everyone else does.
Likes seazal
  • #66
Hey. I just read the space shuttle can land by gliding only, can't a commercial plane do that too? I read
"As others mentioned, it was originally planned to possibly add small jet engines for use in assuring the landing, but after it was demonstrated that a good, trained pilot could consistently (with the on-board guidance computers help) bring it in for a glider-only approach in reasonable conditions, it was decided to not add the considerable weight of jet engines and their added systems, since every single extra pound of weight costs tens of thousands of dollars in added fuel requirements. The pilots practiced over and over and over (literally hundreds of landings if I recall) in specially modified Learjets (that simulated the rather unusually heavy and laggy aerodynamics of orbiters) until they could hit the landing every time.
In the end, seems to have worked…every shuttle orbiter (besides Columbia of course) has landed without any major hitch. If course, if they had been absurdly off course, they always had the option of bailing out with parachutes and ditching the craft.
The OMS engines were probably far too rough-tuned to use for landing, as pilots need to make very small and precise engine adjustments, but that's a guess."
One engine is all they need. Remember that they only need enough power to push it from a shallow glide to level flight. Turns would need to be slow and wide.Certainly, more engines improve safety, but two engines would improve safety so much that having more is not that much better.
  • #67
When younger, I used the pc software MS flight simulator and F-15 Strike Eagle. I crashed the planes about a thousand times. So my other (learnt) concern is that if the airliner pilot is suicidal, he could easily crash the plane. So what kind of airliner has enough redundancies that any pilot can't just suddenly turn the engine off. Could you turn an airliner engine off by just removing a key, like in a car? or not?
By the way. Microsoft Flight Simulator is not better than X-plane?
  • #68
As you have flown both sims, compare them and apply your criteria to decide.
[I'm ignoring the 'car key' question since by now you can likely answer yourself.]
Likes russ_watters
  • #69
I played both, and both are good. The F-15 simulator is pretty complicated for someone who doesn't know the basics though. If you try flying a Cessna, it is much easier than a jet (especially a fighter jet!). And this is where a "discovery flight" in a real plane would probably do you some good, as suggested earlier. You'll have an instructor take you up and then let you fly, and you'll see that the basics of keeping a plane flying are actually pretty easy.
Well sure, if a pilot wants to crash a plane, he can crash a plane. But that is obviously very rare.
MS Flight Simulator was discontinued 10 years ago. It may or may not have been discontinued due to the superiority of X-Pane at the time, but X-Plane at the time had the reputation of having better flight models.
Likes Klystron
  • #70
I'm downloading X-Plane trial now.
When I was using MS flight simulator before, and studying the flight manual for months, I was thinking whether in a real life emergency when the pilots were down. One could land a real plane? Note very importantly that I'm not asking now about landing a plane normally by just learning it from PC. But only asking in an *emergency*. I watched the movie Turbulence once when the actress could land the plane when the pilots got killed. So if you master X-plane. You could do that on an emergency? I know this is very unlikely scenario. But just asking.
The next two years, there will be a shutdown of the LHC, so planning a trip for the first time that would take 10 hours or more. So just want to be prepared psychologically. I heard one can think more clearly in Switzerland and can focus more on stuff beyond the standard model there. Perhaps it's the mood and weather that gives one the focus? Note many physicists love mountain climbing, like Lisa Randall. So mountains and physics seem to jive together.
  • Aerospace Engineering
  • Astronomy and Astrophysics
  • STEM Academic Advising
  • Quantum Physics
