Electrical Engineer Career in Airport: Areas & Qualifications
In summary: An EE in an undeveloped country would probably work on the same types of projects as an EE at a large airport.
evra
86
I want to know in which area can an Electrical Engineer work in an Airport? and What would someone special on to be better in any of the areas in an Airport?
Hope to hear from you soon!
thanks
As i cotrol engineer i guess. Not sure too and i would like to read from others too.
Merci en avance
What would you like to work on? Designing and maintaining runway lighting systems? Design and testing of instrument approaches? Terminal Radar System design? Weather telemetry? Jetway design? Telecommunications for passengers? Baggage handling systems? Backup power generation systems? Fuel delivery systems? Grounding systems?
Now you did say Airport, not aircraft, so I did not even begin to discuss avionics and the like.
This is my meager knowledge as a controls engineer (with an electrical engineering background) and as instrument rated private pilot. I don't do much of this work, but I do have some idea of what goes on there. In general, as airports get sized up, the civil engineers often take the lead, with electrical and RF engineers stepping in as needed.
Larger airports often incorporate SCADA systems to inform them of where things need attention. Examples include RF monitors for instrument approaches, Lighting problems, power distribution problems, drainage problems, and the like.
In our Airport there are barely engineers and i think all u mentioned above are done by technicians and senior technicians. I don't know much so elaborate more on it please and your personal functions there please.
Whats this got to do with working at an airport? If your work for aviation contractor most of your time will be their offices. If you want to work full time in an airport I imagine you will be doing basic repairs & maintenance, not designing TACANs.
Devils, I am also thinking the same way. I don't think airports are good places for Electrical Engineers. Is it?
Allow me to explain: There is such a thing called routine operations, and then there is design.
I know of places where the construction trailers have been coming and going for over 30 years. There is a constant influx of new construction all over the place. Many larger airports are like that. And engineers have reason to want to be at the airport during the commission and startup of new features.
No, you are not regular airport staff. If what you're looking for is a staff maintenance position, then there are no places for an electrical engineer. However, that is not the same thing as saying that electrical engineers don't have much to do in a real airport.
Re-read what I posted, and then consider that airports, particularly large international airports, rarely stay the same. There is always some runway lighting project, some fuel delivery issue, some terminal building construction, a new substation somewhere, a new communications system, new navigation features, and so on and so forth.
And then again, you are writing as if you're located in some other part of the world, and I do not know much about about airspace outside the US, the airports, or airport expansion projects. But as this is a technical, not a political endeavor, I can't imagine that it would be that much different.
The basic point JakeBrodsky and other are maknig is:
Working as an EE at at aiirport is not the same as being an employee of the company that runs the airport.
Obviously there is a lot of electrical equipment in any airport, both airside and groundside. Large airports sometimes have aircraft maintenance facilities as well. But most of the EEs who are involved with all that activity work for the companies that make the equipment, and are not based full-time at the airport itself.
AlephZero, so what about an airport in an undeveloped country, what will be an EE's job in such an airport (state airport)?
AlephZero i am also waiting for a reply on Airer's last question. please
Sorry, I don't have any information about what EE's do at any specific airport in an undeveloped country.
1. What is an electrical engineer's role in the airport industry?
An electrical engineer in the airport industry is responsible for designing, installing, and maintaining the electrical systems that power and control airport operations. This can include lighting, communication systems, security systems, and more. They also play a crucial role in ensuring the safety and efficiency of airport operations.
2. What areas of the airport does an electrical engineer work in?
An electrical engineer can work in various areas of an airport, including the terminal building, airfield, cargo and maintenance facilities, and even in the control tower. They may also work on projects related to airport infrastructure, such as runway lighting, navigation systems, and power distribution.
3. What qualifications are required to become an electrical engineer in the airport industry?
To become an electrical engineer in the airport industry, one typically needs a bachelor's degree in electrical engineering or a related field. They should also have strong knowledge of electrical systems and codes, as well as experience in airport design and construction. Some employers may also require professional certification or licensure.
4. What skills are important for an electrical engineer to have in the airport industry?
An electrical engineer in the airport industry should have strong technical skills in electrical engineering, as well as knowledge of airport systems and operations. They should also have excellent problem-solving and critical thinking abilities, attention to detail, and the ability to work well in a team. Good communication and project management skills are also important.
5. What are some potential career paths for an electrical engineer in the airport industry?
An electrical engineer in the airport industry can advance in their career by taking on more complex projects and assuming leadership roles. They may also specialize in a specific area, such as airfield lighting or power distribution, or move into management positions. With experience and additional education, they may also become consultants or professors in the field.
  • STEM Career Guidance
