Homework Help: Airy equation and solution
  1. Apr 25, 2010 #1
    So the Airy equation states that y''-xy'=0. My problem is to proof that the improper integral
    1/[tex]\pi[/tex] [tex]\int[/tex]cos(1/3*t^3+x*t) from 0 to [tex]\infty[/tex] satisfies this equation.
    I've tried differentiating under the integral sign, but all I've gotten is the integrand to be
    y''+ty = -1/pi [tex]\int[/tex] cos(1/3*t^3+x*t)(t^2+x) from zero to infinity. Naturally I do u substitution, but my final answer comes out to be -sin(infinity)/Pi
    What should I be doing?
    2. Relevant equations
    3. The attempt at a solution
  3. Apr 25, 2010 #2
    vela
    Staff Emeritus
    Education Advisor
    After the substitution, you have
    [tex]y''-xy=\int_0^\infty \cos u\,du[/tex]
    That integral doesn't converge because the integrand doesn't vanish as [itex]u\rightarrow\infty[/itex]. The trick is to introduce an integrating factor [itex]e^{-\lambda u}[/itex] and then take the limit as [itex]\lambda\rightarrow 0^+[/itex].
  4. Apr 25, 2010 #3
    I'm sorry, but i don't quite understand what I do from there. If the integrand is cos u e^-k*u
    it'll converge, but do i find k and why you take the limit as k go to 0 from the right?
    this problem is supposed to be over the heads of students in our class b/c its extra credit and I'm a freshman in a sophomore class, so I don't know if I'm missing anything.
  5. Apr 25, 2010 #4
    vela
    Staff Emeritus
    Education Advisor
    No, you don't find k; you're taking a limit as k goes to 0. The idea is that e-ku will go to 1 as k goes to 0, so the integrand is again just cos u. You have to approach from the right so that -ku<0, otherwise e-ku would go to positive infinity when you plug in the upper limit of the integral.
  6. Apr 25, 2010 #5
    ahhh, my answer works out to zero now. thank you.
  7. Apr 30, 2010 #6
    The only thing I dont get is, if I'm trying to do a proof of y''+xy=0 for a given equation, why am i allowed to put an integrating factor into the equation?? Wouldn't that show I was unable to prove what I wanted to prove?
  8. Apr 30, 2010 #7
    vela
    Staff Emeritus
    Education Advisor
    I should have said "convergence factor," not "integrating factor."
    Honestly, I don't know the mathematical justification for when such factors are allowed and what their requirements are. It's just a technique that I occasionally ran across in physics, but the mathematical theory behind it was never explained.
  9. Apr 30, 2010 #8
    I'll make sure to read up on convergence factors once my tests are over. Thanks for the help!
