Algebra problem
  1. Jan 18, 2006 #1
    I have an algebra problem which is giving me headaches.
    Lt = St
    Lt = Kt+1 - Kt
    St = s * Yt
    Kt = k * Yt
    K0 = 200, s = 0.3, k = 2
    Prove that Kt+1 = 1.15 * K
    Thanks.
  3. Jan 18, 2006 #2
    Now I'm not sure if this is correct, but I started off by subsituting in the known values.
    Lt = St
    Lt = Kt+1 - Kt
    St = 0.3 * Yt
    Kt = 2 * Yt
    Lt = St
    Lt = Kt+1 - Kt
    St = 0.3 * (0.5 * Kt)
    0.5 * Kt = Yt
  4. Jan 18, 2006 #3
    HallsofIvy
    Since the very first equations says Lt= St, you can simplify slightly by writing that third equation as Lt= 0.3Yt. You now have 3 equations:
    Lt= Kt+1- Kt
    Lt= s Yt
    Kt= k Yt
    Also, You say you want to prove "Kt+1= 1.15*K" which makes no sense. I imagine it must be either "Kt+1= 1.15*k" or "Kt+1= 1.15*Kt". I suspect it is the latter.
    Since, however, you want Kt+1= something, I suggest rewriting that first equation as Kt+1= Lt + Kt (add Kt to both sides). Now, it looks to me like you just need to replace that Lt with something!
    You know that Lt= sYt. do you see that Yt= (1/k) Kt? That should make it clear!
  5. Jan 18, 2006 #4
    The sheet I was given says "Prove that Kt+1 = 1.15 x K" with the K in upper case.
  6. Jan 18, 2006 #5
    VietDao29
    I think that's a little typo. The sheet should read:
    Kt + 1 = 1.15 Kt.
    You can follow HallsofIvy's post, and you'll soon arrive at the answer,
    or you may also want to try a slightly different way:
    St = Lt
    <=> s Yt = Kt + 1 - Kt.
    What's Kt + 1? What's Kt?
    Can you go from here?
  7. Jan 18, 2006 #6
    I have also been able to confirm that the equation:
    Kt+1 = 1.15 * K
    should read:
    Kt+1 = 1.15 * Kt
    From the help that HallsofIvy and VietDao29 provided, you should come to the answer.
    I came to the answer a different way, but want to find out if you can use their help before I make another post.
