Homework Help: Algebra question
  1. Dec 29, 2012 #1
    Let Sn = n2+20n+12, n is a positive integer. What is the sum of all possible values of n for which Sn is a perfect square ?
    2. Relevant equations
    3. The attempt at a solution
    Well, I tried to factorise it : n2+20n+12 = n2+20n+100-88
    =(n+10)2-88. And I conclude that there are infinitely such values of n...
    I also tried to search properties of perfect squares but could find none applicable here.
    To my surprise, answer is 16 ....
    How is it like that ???
  3. Dec 29, 2012 #2
    Dick
    Suppose (n+10)^2-88 is a perfect square. Call it k^2. Then (n+10)^2-88=k^2. So (n+10)^2-k^2=88. Start factoring both sides.
  4. Dec 29, 2012 #3
    That's what I can do without much effort ...
    it's
    (n+10+k)(n+10-k) = 88
    What next ???
  5. Dec 29, 2012 #4
    Dick
    Start listing ways to factor 88 and try to match the factors with factors on the left. Figure out which ones work.
  6. Dec 29, 2012 #5
    I guess next we need to factorize 88. It's 11*2^3 ..
  7. Dec 29, 2012 #6
    Dick
    How many ways to split that into two factors that you can match with the algebra factorization?
  8. Dec 29, 2012 #7
    haruspex
    There's a shortcut you can use with these. Consider the difference between the factors. Can you say whether it is even or odd? What does that tell you about the parity of the factors?
  9. Dec 30, 2012 #8
    Since difference of factors is 3 ...
    so,
    (n+10+k)-(n+10-k)=3
    => 2k=3
    =>k=2/3
  10. Dec 30, 2012 #9
    HallsofIvy
    You have been told, repeatedly, to find all the ways of factoring 88 into two factors. But you still have not done that.
  11. Dec 30, 2012 #10
    Mentallic
    What? How did you come to that conclusion?
  12. Dec 30, 2012 #11
    Dick
    You mean k=3/2. And that just shows that 11*8 is not a factorization you want. Try another one.
  13. Dec 30, 2012 #12
    Mentallic
    Ahh :smile:
  14. Dec 30, 2012 #13
    Oh my god! It was awfully easy:
    Factors of 88 -->
    1*88
    2*44
    4*22
    8*11
    Assuming
    n+10+k = 44 and n+10-k = 2;
    we have 2n+20=46 =>2n=26 => n = 13
    And putting it in n2+20n+12, we have 441 whose root is 21 ... 1st number = 13
    again taking n+10+k = 22
    and n+10-k = 4;
    2n+20 = 26
    => 2n = 6
    => n = 3 ..... 2nd number
    so
    (3)^2+20(3)+12 = 81 root of which is 9...
    so the two numbers 13 and 3 add up to 16, that's it.
    Thanks everybody a lot.
  15. Dec 30, 2012 #14
    haruspex
    Just to explain the shortcut I was trying to get you to find, the difference of the factors is 2k, so even. Therefore the two factors are either both even or both odd. Since the product is even, they must both be even. So you can start by assigning a factor of 2 to each, and then you are just left with either 1 x22 or 2 x11 for the remaining 22.
  16. Jan 1, 2013 #15
    Yea, that also works and even better, no need to search other factors. Thanks a lot. I tried it also.
Loading...
Similar Threads for Algebra question Date
Vector Spaces Question Aug 28, 2017
Multiple in logarithm question -- find the variable? Jun 23, 2017
Simple Algebra Question Dec 7, 2016
Algebra simultaneous equations Question Oct 21, 2016
