How do I show that unitary maps form a group under multiplication?
  • Thread starter sarahr
  • Tags
    Algebra
In summary: Therefore, U is a group under multiplication.In summary, the unitary maps form a group under multiplication, where the identity, the product of two unitary maps, and the inverse of a unitary map are all unitary maps. This is shown by using the definition of a unitary map and the fact that M*M = I for all unitary maps M.
sarahr
i need to show that the unitary maps form a group under multiplication. I've never had algebra (im in linear algebra) so this is the first time I've seen this idea of 'groups'. i tried to look stuff up, so i think i see now that i need to show: 1) identity is an element 2) if x,y are elements of the group then the product xy is in the group 3) if x is an element, then its inverse is in the group.
I'm not really sure how to show these things since I'm new to this. :bugeye: All I really have to work with is that a unitary mapping M satisfies ll Mx - My ll = ll x - y ll for all x,y.
Can you help me get started? Thanks, Sarah :)
Technically, you also need to check that multiplication is associative, but that can probably be taken for granted here. So, show:
1) The identity map is unitary [this is really, really easy]
2) If X and Y are unitary, then XY is unitary [the only thing easier than this is 1)]
3) If X is unitary, then a) X-1 exists and b) X-1 is unitary.
You must be able to do 1) and 2) without help, and at least make some effort and show some work one 3a) and b) before anyone should help you here.
I think I'm getting there now.
Let U be the collection of unitary maps. I need to show that U is a group under multiplication.
1. the identity is an element of U because:
I*I = I , therefore I is an element of U.
2. Let M1, M2 be elements of U. I need to show that M1M2 is an elt. of U:
(M1M2)*(M1M2) = I
Now the LHS is = (M2*M1*)(M1M2)
= M2*(M1*M1)M2
= M2* (I) M2
= M2*M2
= I
therefore M1M2 is an elt. of U
3. for the inverse, I can just refer to another homework problem i was assigned before this where we showed this. I got that one.
I'm obviously using here that a unitary map M satisfies M*M = I. I didn't realize I could use that for this problem. Then I did and it become much clearer.
It's just as easy doing it using the definition that M is unitary iff ||Mx - My|| = ||x - y|| for all x and y.
1. ||Ix - Iy|| = ||x - y|| so I is unitary
2. If M, N are unitary ||MNx - MNy|| = ||Nx - Ny|| = ||x - y||, so MN is unitary
3. If M is unitary and M-1 exists, then:
||M-1x - M-1y||
= ||MM-1x - MM-1y|| (since M is unitary)
= ||Ix - Iy||
= ||x - y||
so M-1 is unitary. To prove M-1 exists, suppose it didn't. Then there would exist non-zero x such that Mx = 0 (because M is linear, which you forgot to mention in your opening post). But then:
= ||0 - 0||
= ||Mx - M0|| (since 0 = M0 and 0 = Mx)
= ||x - 0|| (since M is unitary)
> 0 (since x is non-zero)
0 > 0 is a contradiction, so M does have an inverse.
1. What are unitary mappings in algebra?
In algebra, unitary mappings refer to a type of function that preserves the inner product of two vectors. This means that the angle between two vectors remains the same after being transformed by a unitary mapping.
2. How are unitary mappings different from other mappings?
Unlike other mappings, unitary mappings preserve the length and angle between vectors. This makes them useful for preserving geometric properties and solving equations in algebra.
3. What is the importance of unitary mappings in quantum mechanics?
In quantum mechanics, unitary mappings are important because they preserve the probability of a quantum state. This is essential for understanding and predicting the behavior of quantum systems.
4. Can unitary mappings be represented by matrices?
Yes, unitary mappings can be represented by unitary matrices. These are square matrices with complex numbers as entries, and they have the property that their conjugate transpose is equal to their inverse.
5. How are unitary mappings used in data compression?
In data compression, unitary mappings are used to transform data into a new basis that is more efficient for storage and transmission. This is because unitary mappings can reduce the redundancy and correlations in data, making it easier to compress.
  • Linear and Abstract Algebra
