Algebraic vectors
if i had to find a vector of magnitude 27 units which is parallel to 3i+ 4j, what do i have to do first? would i express my answer in ordered pair notation?
Answers and Replies
Hootenanny
Staff Emeritus
I would express your answer in terms of unit vectors. Ordered pair notation is uaually used to define co-ordinates. Remember parallel vectors must be multipuls of each other.
~H
would this be a sufficient answer:
let u be the vector.
the magnitude of 3i + 4j is 5
27/5 = 5.4
since parallel vectors are multiples of each other, we can just multiply (3i + 4j) by the scalar 5.4
so u = 5.4(3i + 4j)
= 16.2i + 21.6j
this is what i came up with before but it seems messy (decimals) and and kind of an inefficient solution
arildno
Dearly Missed
9,970
134
Seems good to me, but why not write your answer as:
[tex]u=\frac{27}{5}(3i+4j)[/tex]
Note that [itex]\frac{1}{5}(3i+4j)[/itex] is a UNIT vector.
Hootenanny
Staff Emeritus
Who said it wasn't a unit vector?
arildno
Dearly Missed
9,970
134
Noone. I just wanted to emphasize that, so that OP could see how a unit vector naturally would occur in his expression.
Hootenanny
Staff Emeritus
Ahh right, I thought I'd made a mistake somewhere :confused: .
arildno
Dearly Missed
9,970
134
No, but I wanted OP to see why your suggestion
"I would express your answer in terms of unit vectors."
is, indeed, the most natural one.
Hootenanny
Staff Emeritus
Good point, I should have emphisised (but I didn't get the chance :wink: )
guys, i have some more questions if you don't mind.
state whether the following expressions are vectors, scalars or meaningless:
a) (a+b) • (a+c)
b) (a • a)b
c) (a • b)• c(b × c)
note that all the letters are vectors (so picture arrows on top of them)
mostly i need to clairify some things. first, whats the difference between a scalar and something meaningless? also for b) and c), what does something like (a • a)b compute to. does the b multiply, or dot, or cross or what?
arildno
Dearly Missed
9,970
134
Something "meaningless" is an indicated operation between quantities that the operation in question cannot, by definition, be used upon.
oh ok, so since the dot and cross products are only applicable to vectors, if a scalar was involved in one of them, the result would be meaningless?
to restate my other question, what does the b part of (a • a)b compute to. does the b multiply, or dot, or cross or what?
arildno
Dearly Missed
9,970
134
Remember that you have 3 basic product operations with vectors:
1. Dot product: Takes two vectors and produces a scalar.
2. Cross product: Takes two vectors and produces a vector.
3. Scalar multiplication: Takes a scalar and a vector, produces a vector that is parallell to the original vector.
thanks for the summary but the way (a • a)b is written, and considering b is a vector and not a scalar, what is the operation here?
arildno
Dearly Missed
9,970
134
What does a parenthesis usually signify for the order of operations performed?
so i think your referring to doing the inside of the brackets first; a dot product operation yielding a scalar. so then does it leave a scalar multiplying a vector?
arildno
Dearly Missed
9,970
134
What do YOU think?
lol that's what i think, i do have some doubt however because as you look at c) (a • b) • c(b × c), the second part of the question (c(b × c)) is somewhat confusing. you basically get a vector multiplying a vector without dot or cross product operation (the only two ways you can muliply vectors i'm aware of). although this does not change the outcome of the question since the first part of the question is a scalar and yielding the result meaningless.
arildno
Dearly Missed
9,970
134
Correct!
Either way you are looking upon the last one, either as:
[tex]((a\cdot{b})\cdot{c})(b\times{c})[/tex]
or as:
[tex](a\cdot{b})\cdot({c}(b\times{c}))[/tex]
the expressions are meaningless.
(a • a) would result in a scalar value
hence that scalar result would then have to be multiplied with the vector b (scalar multiplication)
The final answer is a vector
another question...
A parallelogram PQRS has vertices P(1, 3, 1), Q(4, 5, −2), S(−2, 3, −5). Determine
a) the coordinates of R
b) the perimeter of the parallelogram
c) the area of the parallelogram
if it was in 2-d if would be so much better but this is so hard to visualize!!
for a) i know i have to come up with an equation like PQ = RS, but then what do i do from there. do i add P and Q (R and S), subtract or what?
Hootenanny
Staff Emeritus
You must first find the vector equation of the line PQ.
~H
You need to specify that the vertices are taken in order as well, otherwise there are three possible values for the coordinates of R.
You can also approach the problem non vectorially .
What is the property of the point of intersection of diagonals of a parallelogram ?
For the area bit, I'd say vectors are cool .
Hootenanny: we haven't learned vector equations...i think were supposed use vector operations (adding and subtracting) to solve for R.
arunbg: what order are you talking about?
Related Threads on Algebraic vectors
  • Last Post
  • Last Post
  • Last Post
11K
  • Last Post
  • Last Post
  • Last Post
