Are all line segments truly equal?
  • I
  • Thread starter thinkandmull
  • Tags
    Line
In summary: This is known as a bijection, which does not necessarily preserve length. In summary, the paradox of a longer line being put at an angle with a shorter one can be resolved by understanding that bijections do not always preserve length. Instead, it is a fact of nature and math that the number of points in both segments is the same, even if the length of one appears to be longer.
thinkandmull
51
Hello,
If someone takes two segments, one longer than the other, it is naturally assumed that the longer one is most definitely longer than the other. However, if the longer segment is put at an angle with the other to make a triangle, suddenly someone can draw a one to one correspondence between all the points on the original two segments. So the line was not really longer. How can we resolve this paradox?
Mathematics news on Phys.org
There is no paradox. Bijections do not, in general, preserve length.
I agree it looks weird and suspicious. But the correct resolution is to stop seeing it as a paradox and more as a fact of nature/math.
Couldn't you do that even without putting the longer line at an angle with the other?
Is this what you have in mind?
Here I'm showing two points on each line, with their distance exaggerated for clarity. Although there's a one to one correspondence, the distance between the two points on the longer line is greater than the distance between the two points on the shorter line.
The longer segment has a length that is larger, but both segments contain the same number of points. Another way to say this is that the cardinality of both segments is the same.
1. What does it mean for all line segments to be equal?
When we say that all line segments are equal, it means that they all have the same length. This means that if you were to measure each line segment with a ruler, they would all have the same measurement.
2. Are all line segments equal in all shapes?
No, not necessarily. While some shapes, such as squares or equilateral triangles, have all equal line segments, other shapes may have varying lengths for their line segments.
3. Why is it important for line segments to be equal?
Having equal line segments is important in geometric shapes because it helps maintain symmetry and balance. It also allows for easier calculations and comparisons between shapes.
4. How can you prove that all line segments are equal?
To prove that all line segments are equal, you can use a ruler to measure each line segment and compare their lengths. Additionally, you can use mathematical equations and principles to show that the line segments are equal.
5. Can line segments be equal in a three-dimensional space?
Yes, line segments can still be equal in a three-dimensional space. Just like in two-dimensional shapes, equal line segments in three-dimensional shapes have the same length and can be measured using a ruler.
  • General Math
  • General Math
  • General Math
  • General Math
