Can the Speed of Light Be Changed and What Does It Mean for Space Exploration?
In summary: Light. Then, you could change it to whatever you want.In summary, the speed of light is defined as what it is in a vacuum. Everyday circumstances can alter the speed of light, but this has no implications for space travel.
  • #246
so you find the length of a moving object by the time*speed?
Science news on Phys.org
  • #247
Why is it that when objects only loose length when traveling at relativistic speeds? Well, it is noticeable at relativistic speeds. What actually defines the magnitude of relativistic speed? When do you start applying the Lorentz Transform and why?
In addition to the statement about length contration, I would like to say that length is not PHYSICALLY lost. In one reference frame the length of an object at relativistic speeds is contracted, while relative to that object it is the same. It is not physically lost, because it is contracted and proper in two reference frames. This is contradictory. Nothing can loose length and keep it at the same time. Just my two coins going in.
  • #248
Since everyday speeds are nothing compared to the speed of light, the length contraction/time dilation/mass increase are neglected. When moving at relativistic speeds (close to the speed of light) these effects are very noticable. For example, mass is a little more than 2 times greater at .9c than the rest mass. Which shows that you have to get very close to the speed of light for the mass to start sky rocketing.
Correct, nothing is physically happening to it, there is no force making it contract. It simply IS shorter at a certain velocity.
  • #249
As was discussed several posts ago, one way of measuring the length of a moving object is to time how long it takes to pass you, then multiply that time by its speed.
  • #250
And what is your opinion about tachyons, do they exist? Sorry if anyone asked this before.
  • #251
What is the barrier when you start considering speeds relativistic?
How is it simply shorter and at the same time simply the same size as it is when considered at rest to itself?
  • #252
There isn't one. All speeds are relativistic. Now as to the related question, "When do you have to use relativity, and when can you get away with not using it?" the answer is another question: "How accurate do your calculations need to be?"
It is shorter than its proper length according to an observer watching it move by.
It is exactly its proper length in its rest frame.
You have to qualify observational statements with the frame in which the observation is made to make any sense.
  • #253
How can it have two lengths at the same time? Isn't that impossible. I know this is in regards to different inertial reference frames, but reference frames doesn't make something heavier or lighter depending on the speed of one related to another. That would make something have two different masses at the same time.
A good explanation would help me understand.
  • #254
Because it happens to be a feature of the universe we live in that the length of an object is a function of its speed.
No, it isn't. In fact, it's quite impossible for it not to be that way!
The concept of relativistic mass can be accepted or abandoned at will, but we are stuck with length contraction and time dilation. So, I'll be confining my remarks to the latter two phenomena.
It all starts with Maxwell's equations of electrodynamics. This is how Einstein derived Special Relativity from two postulates:
1. The laws of physics must be the same in every inertial frame.
2. The speed of light must be the same in every inertial frame.
The first postulate means that you should not be able to tell whether you are moving or at rest merely by performing an experiment in a closed laboratory. What it really amounts to is that there is no such thing as a state of absolute rest. Equivalently, it means that there is no preferred inertial frame of reference.
The second postulate means that, for any light pulse, its speed will be measured to be 'c', no matter what the relative motion between the source and the observer. So if a source is stationary in your frame and you measure the speed of a pulse, it is 'c'. And if that same source comes at you at 0.5c and you measure the speed of another pulse, you still measure the speed to be 'c' (not 1.5c!).
That second postulate gives an inkling of length contraction and time dilation: Space and time cannot possibly be reckoned the same for all observers, if the speed of light is reckoned the same for all observers.
Now back to Maxwell. What Einstein did was pose the question, "What sort of coordinate transformation would leave Maxwell's equations in the same form for all inertial observers?" This question is relevant because of the first postulate. If the laws of physics have to be the same for everybody, then the equations have to be the same for everybody. Einstein didn't just pose the question, he also answered it: The coordinate transformation is the Lorentz transformation.
And derivable from the LT are the formulas for length contraction and time dilation. So the best way I can think of the "explain" these phenomena is to say that they are deduced from the postulates of SR, which in light of all the experimental data are eminently reasonable, and the covariance of Maxwell's equations, which are well-confirmed experimentally.
  • #255
We are not necessarily stuck with length contraction or time dilation. I've seriously been a firm believer in Einstein's theories, but as of lately, I've kind of trailed off thinking less of what he has theorized.
Time dilation has been tested, and scientist would even say it is proven to exist. I would have to argue that statement. Length contraction has never been observed, nor has mass increase been observed (Not sure about the mass increase, but I'm thinking it hasn't been measured, so don't go too hard on that one).
Would you like to explain to me exactly how light keeps it's constant velocity? I am in accordance with Maxwell saying the frequency is inversly proportional to the wavelength only when the source and detector are stationary. What I do not believe is that this is true when velocity of the source of detector is thrown in. I have no belief that the Lorents Transform did a good job in explaining this phenomenon. So, saying what you just said, has not influenced my thought. Can you go more indepth? I'm going astray; I need to get back on path with physics. :rofl:
  • #256
Yes we are.
There's nothing to argue. Time dilation has been observed, and in the precise quantities predicted by relativity.
That's true. But the invariance of the speed of light has been observed, and so has time dilation. It is not logically possible for space to be absolute, when the speed of light is absolute and time is not.
As I already said, "mass increase" is a matter of convention, not physics. If you define mass as m=γm0, then you will observe that that quantity increases with speed. It's done all the time in particle accelerators. But most particle physicists define mass as the norm of the 4-momentum, and as such it is a Lorentz invariant.
No one knows why. We only know that it is true.
It doesn't matter if you believe it or not. The speed of light has been measured from moving sources. The most direct test has been performed by T. Alvager, et al, Physical Letters 12, 260 (1964).
Look it up.
The Lorentz transform doesn't explain the phenomena, it predicts them. I said that the explanation is in terms of the postulates: Time dilation and length contraction are necessary, deductive consequences of the postulates.
But since the postulates and the transforms have survived every experimental test with flying colors, I'll say it again: it doesn't matter in the slightest what you believe.
  • #257
say there is a ship going .90c we figured out the length of the ship from the viewpoint of something going .30c. if we were standing still and shot two knives that go .30c, the same distance apart from each other as the ship's length we figured earlier, would we miss the ship or would the ship get cut into three portions?
  • #258
You need to be more specific. First, are the knives moving perpendicular to the path of the ship, or antiparallel to it? This matters because length contraction is only in the direction of relative motion. So, if the knives are moving perpendicular to the path of the ship, then a person in the frame of the knives would agree with an observer in the lab frame as to the length of the ship.
Second, you should assign spacetime coordinates to each event, and state where the ship is when the knives are launched.
There's a false dilemma here, because those aren't the only 2 options. Depending on when you shoot the knives, it's possible that only 1 knife will hit the ship.
  • #259
the ship's and the knives' path are to intersect at the exact same time.
  • #260
why doesn't time move slower at the equator than at the poles?
  • #261
That doesn't help, because you have to say which knife is to intersect the ships path when the ship gets there. As I already said, in the frame of the knives, the ship is too short to be hit by both of them.
  • #262
Why would you think that time dilation is inapplicable here?
  • #263
so if i lived on the equator i would live longer than if i lived on the northpole? granted i don't die of any other reason other than old age.
  • #264
You haven't given enough information but if we assume that the knifes are fired simulataneously in the gun's refernce frame in such a manner that the front of the ship is 'clipped' by the knife on the right.
What happens in the gun's frame is simply that the knife 'clips' the front of the ship, but the knife on the left misses the ship completely due to the fact that the length of the ship is contarcted in this frame.
In the shi's frame the length of the gun is contracted, howver the knifes are not fired simulatanoeusly; the knife on the right fires first and the ships front is 'clipped', then the ship moves on and the knife on the left fires missing the ship completely.
The lengths of the knifes are the same in both frames.
  • #265
the knives are the same length apart from each other so that one would slide past right in front of the ship and one would slide right behind the ship. they both cross the ships path at the same time.
  • #266
It's not possible to tell for certain from your language, but you seem to think that the ship should fit snugly between the two knives, which is wrong. As I've said twice already, the ship has the same length in the frame of the knives as it has in the frame of the knife launcher.
  • #267
Longer as measured by whom? You would not notice your life being any longer, of course, because relativistic effects always turn up in the other guy's frame.
It seems like you have not looked at that relativity textbook I linked you to. If you learn the material in that link, you can answer all these questions for yourself.
  • #268
As Tom Mattson says length is frame dependent and the length of the ship is contracted (i.e. smaller) in the gun's and the knife's frame, only the proper lengths are the same.
  • #269
why would one be shot off sooner than the other, from the view of the ship, if they are both shot at the same time from the view of the gun?
  • #270
Of course you could mean that the length of the ship is L in the gun's frame (which means that the proper length of the ship would actually be greater than 2L) in which case both front and back will be clipped under the previous assumptions (simultaneously in the gun's frame, non-simultaneously in the ship's frame) .
  • #271
Because of the failure of simultaneity at distance in relativity - i.e. events that are simultaneous and separated by distance in one frame are not simultaneous in another frame.
  • #272
Because simultaneity is relative. Events that are spatially separated and are simultaneous in one inertial frame, are not simultaneous in any other inertial frame.
It's all spelled out quite clearly in that book I linked you to.
edit: jcsd already got it, I see.
Here's that link again, in case you change your mind about reading it:
Special Relativity
  • #273
that does not make sense. say I am traveling in a ship that its width is longer than its length and another ship flies perpendicular to me at a speed of .90c then my ship will look like its slanted to the right? both of my side are moving at the same time in the view of my ship.
  • #274
In general extended objects are rotated in a frame in frames that are moving relative to those objects.
And as we keep repeating, simultaneity is relative. Two events that are spatially separated and simultaneous in one inertial frame are not simultaneous in any other inertial frame.
  • #275
so then things that are farther in front of the ship are then closer together from the ship view?
  • #276
I can't answer that, because this question is ill formulated. You haven't specified the state of motion of the "things" in front of the ship. If they are stationary with respect to the ship, then the distance between the ship and the things is a proper length, and it would be shorter from the point of view of someone watching the ship pass by. If the things are stationary with respect to the onlooker, than the distance will be shorter from the point of view of the ship.
Bino, please read the link I gave you. You keep asking the same type of questions over and over and over and over and over and over..., and this rapid fire questioning is getting tiresome. Please take some of the responsibility of your own education. You'll be the better for it.
  • #277
Well, you also have to consider gravitational time dilation since the Earth isn't a perfect sphere...
  • #278
Just to amplify a few things about this last point...
One of the very interesting facts of life is that all clocks on the Earth's surface at sea-level (the geoid) run at the same rate. The reduced gravitational potential at the Earth's equator due to it's equatorial bulge exactly cancels out the time dilation due to the rotational motion.
Atomic clocks are precise enough nowadays that these issues are actually important - one of the primary clocks at Denver, Colorado, has to have it's contribution to atomic time (TAI time) adjusted because of it's altitude above sea level.
  • #279
good to know pervect
  • #280
i don't understand how the michelson-morley experiment could have worked in the first place. everything is fixed to the Earth the speed of light could not have changed anyway. how does that have to do with the rotation of the earth?
