- 77
- 1
aluminium framework.....
I am designing an aluminium frame bed. I have desided to use aluminium extrusion either square or rectangular shape to form the main 4 bars at the base supported by 4 legs. I will use panels of plywood at the centre holding the mattress.
My question is.......suppose the structure needs to support 90kg, should i assume an evenly distributed load of 90kg on each memeber or does it require more thought as to where most of the load is applied to the structure? - (e.g. at the top and bottom ends near the feet and head it would be at its minimum but the main 2 or 3 cross plywood panels in the centre would need to support the bulk of the 90kg)
Tips and ideas would be much appreciated...
