Aluminum Engines: What Prevents Warping?
In summary, the Vega engine uses a sleeveless aluminum block that does not have cylinder liners. This makes the block less expensive to manufacture. Special chrome-plated piston rings were developed for the Vega engine. The large bore, long stroke design provided good torque and lower engine RPM for reduced wear. The cast iron cylinder head was chosen for low cost and structural integrity.
Xyius
508
Hello all,
Most engines today in passenger cars are made out of aluminum instead of iron. I am confused about the fact that aluminum is lighter than cast iron and warps easier under extreme temperatures. How do they stop this warping from occurring?
By manufacturing within the tolerances of the materials and using alloys.
Some aluminum blocks use cast iron sleeves for the cylinders to take the most severe heat.
Likes Greg Bernhardt
Here's one method described in the COMPLETE VEGA HISTORY 1970-1977:
Vega's most unique feature was its 2.3 Liter (140CID) OHC four-cylinder
engine. Unlike previous GM aluminum engines, the Vega block did not have
cylinder liners. GM Research Labs had been working on a sleeveless
aluminum block since the late 50's. The incentive was cost. Getting rid
of those liners on a four-cylinder block would save $8, which was a lot
of money back then. This involved a joint venture between the GM labs,
Reynolds Metal Company, and Sealed Power Corporation. Reynolds came up
with an alloy called A-390, composed of 77 percent aluminum, 17 percent
silicon, 4 percent copper, 1 percent iron, and traces of phosphorus,
zinc, manganese, and titanium. The A-390 alloy was suitable for faster
production diecasting. These qualities made the Vega block less
expensive and easier to manufacture than other aluminum engines! A
process of etching the cylinder block walls exposing the silicone
particles insured a wear surface stronger than steel. Sealed Power
developed special chrome-plated piston rings for this engine that were
"blunted to prevent scuffing. The large bore, long stroke design
provided good torque and lower engine RPM for reduced wear. A cast iron
, and an
overhead cam was specified.
I re-read the OP and found out that you worry more about warping than wear.
The first engine part to be made of aluminum were the pistons. Those didn't warp. Then, they made the cylinder heads. They didn't warp either. Even though these two parts constitute the walls of the combustion chamber. Doing the block afterward is a breeze (warp-wise), since it is subjected to less heat as the piston moves down. Wear is more of concern.
If a piece is thick enough, it won't warp (and piston tops and cylinder heads are thick). If you made the cast iron engine thin enough, it would warp too, as you can see with this skillet (source):
Aluminium engine parts are more prone to warping than the equivalent steel part if something goes wrong - so the other way to answer this question is "they don't" (stop the warping from occurring). But this is a bit simplistic - the cooling system in aluminium engines is critical, and other strategies like alloys and sleeves (iron, steel, or ceramic) are used.
Note: the Corvair used to have a rep for stripping cylinder heads ...
It's difficult to know how to answer the question properly because it is so easy just to google for the basic stuff.
eg. http://en.wikipedia.org/wiki/Aluminium_alloy#Aluminium_alloys_versus_types_of_steel
Also: "build in better cooling", is pretty much the answer included in the question.
Sorry for the late reply! Thanks guys!
Just a comment on alloys: you can find pure aluminium about as often as pure iron (instead of steel): not at all. It exists for some special applications, but basically all consumer products have some other elements mixed in.
Not directly related to this thread, but made interesting reading for a current problem I had with a part of an automotive engine, alloy timing chain housing, a stud sheared off and in our trade we have always applied heat to the alloy to try and loosen the stud/bolts, but in this example the stud sheared again. Reading the research from the link provided helped me to understand that as alloy ages and working temperatures change over time, the alloy material structure changes and hardens, thus no oxidation or corrosion needs to occur because the alloy alone will harden around the mild steel bolt/stud and can make it practically impossible to remove after a long ageing period.
Freezing the alloy seems to be the better option to try and remove studs/bolts, but assume is costly?
Likes Modulo2pi
1. What causes aluminum engines to warp?
The main cause of warping in aluminum engines is excessive heat. When the engine is running, the metal expands due to the high temperatures. If the engine is not able to dissipate this heat properly, it can cause the metal to become distorted and warped.
2. How can warping in aluminum engines be prevented?
Proper maintenance and care can prevent warping in aluminum engines. This includes regular oil changes, monitoring the engine's temperature, and avoiding overloading the engine. Additionally, using high-quality engine components and materials can help prevent warping.
3. Can warping in aluminum engines be repaired?
In some cases, minor warping in aluminum engines can be repaired. However, it depends on the severity of the warping and the specific engine. In many cases, the best solution is to replace the warped parts or the entire engine.
4. Are there any benefits to using aluminum engines?
Yes, there are several benefits to using aluminum engines. They are lighter and more fuel-efficient than traditional cast iron engines, which can improve vehicle performance and fuel economy. They also have better heat dissipation, reducing the risk of warping.
5. Are there any other common issues with aluminum engines?
In addition to warping, aluminum engines can also be prone to corrosion and electrolysis due to their composition. This can be prevented by using high-quality antifreeze and regularly flushing the cooling system. Some aluminum engines may also have issues with head gaskets, which can be prevented by using proper torque specifications and high-quality gaskets.
  • Mechanical Engineering
47K
  • Materials and Chemical Engineering
11K
  • STEM Career Guidance
