Why is air always cold when it moves at high speeds?
  • Thread starter Raza
  • Tags
    Cold Wind
In summary, the high velocity of air motion causes the air to be colder than if it were at a slower velocity, because the air can remove heat from the body faster.
Raza
203
Why is it that air going at a high rate of speed always cold? For example, fans throws air at high speed and it's cold and when we, human blow air fast is always cold.
WHY?
The air is not actually at a different temperature just because it's moving fast. In other words, it's not really colder.
It just happens that a fast-moving stream of air is capable of carrying heat away from something (i.e. your body) faster than a slow-moving stream of air.
- Warren
- Warren
You can prove this for yourself, too. Simply get a fan, put a thermometer in front of it, and notice that the temperature does not change regardless of whether or not the fan is blowing (as long as it is not in the sun).
That's really phenomenal!
I guess that's the way windchill works.
Yep, that's wind chill.
If you walk out of a warm building into a cold evening, you'll get chilled faster if the wind is blowing than if it's not. This is because moving air can remove heat from your body faster than can still air.
If you live in a hot climate, you can experience the same thing in reverse, too. If you walk out of a cold air-conditioned building into a very hot summer day, you will warm up faster if the wind is blowing than if the air is still. You might even feel like the wind is hot, like someone's aiming a hair dryer at you. This is the opposite of "wind chill," but it is the same effect.
- Warren
You will notice also that the effect is far more pronounced if you're wet. Moving air amplifies evaporative cooling.
More importantly I think that others have fail to state is its to do with Newtons laws of cooling, forced convection moves away 'preheated' air allowing for a faster expenditure of heat from an object ( say the body) than a sample of air with a temperature excess closer to zero (the temp of the object w.r.t. the temp of environment), it is exponentially proportional
As Funker impled, heat up the thermoter a bit first, and it will cool off faster with the fan on than with the fan off.
As a motorcycle rider, it has to get pretty hot before the wind fails to cool you off significantly. I don't recall it ever being so hot that moving was hotter than not moving (must be sweating / wind cooling effect).
I agree the main "wind chill" effect is because of increased convenction cooling, but you need to be careful interpreting experiments like "putting a thermometer in the flow to measure the temperature".
There is a similar temperature effect to the Bernoulli effect on pressure:
T = t + v^2/2Cp
T = the stagnation (total) temperature of the gas
t = the static temperature
v = velocity
Cp = specific heat.
In that sense, increasing velocity (by a fan) can reduce the static temperature. What you measure with "a thermometer" depends on the local flow pattern round the thermometer. The velocity at the stagnation point on the upstream side of the thermometer is zero. And the velocity on the surface of the thermometer is zero everywhere, if you believe that classical boundary layer theory is exact.
What is "Always Cold Wind"?
"Always Cold Wind" refers to a type of wind that is characterized by consistently low temperatures and a chilling sensation.
What causes "Always Cold Wind"?
"Always Cold Wind" is typically caused by a combination of atmospheric conditions, such as cold air masses and high wind speeds, that result in a constant flow of chilly air.
Where is "Always Cold Wind" most commonly found?
"Always Cold Wind" can be found in various regions, but it is most commonly found in areas with high altitudes, such as mountainous regions, and in polar regions.
Can "Always Cold Wind" be dangerous?
Yes, "Always Cold Wind" can be dangerous as it can lead to hypothermia, frostbite, and other cold-related health issues if proper precautions are not taken.
How can one protect themselves from "Always Cold Wind"?
To protect oneself from "Always Cold Wind", it is important to dress in warm layers, cover exposed skin, and seek shelter in a warm and protected area when possible. It is also important to stay hydrated and nourished to maintain body heat.
  • Other Physics Topics
10K
  • DIY Projects
