Amonium Poly Cret
  • Thread starter miloziz
Can i used amonium poly cret in place of cmc or hec in water based paints?
what beneft give flow property? rehelogy & leveling?
Answers and Replies
chemisttree
637
You need to better define your terms. I assume you mean ammonium polyacrylate (poly cret?) and carboxymethylcellulose (cmc?) and hydroxyethylcellulose (hec?)?
yes, that is correct
chemisttree
637
Thickeners of any type are used to keep the pigment suspended and to prevent sag while thinning sufficiently to allow for easy mixing and good flow. The ammonium acrylates can be used in place of CMC and HEC thickeners but the term 'ammonium acrylate' is not a sufficient descriptor to give you any specific information. These acrylates are usually available as a copolymer specifically manufactured for specific applications. The exact nature of the copolymer is usually proprietary in nature. If you are modifying an existing formulation, the compatibility of each of the ingredients with the acrylic will have to be determined.
No one knows the advantages and limitations of these materials better than the manufacturer so perhaps you should start there. BF Goodrich (search Carbapol), Rohm-Haas (search Acrysol), Archem (search Arcosperse).
Related Threads on Amonium Poly Cret
  • Last Post
12K
  • Last Post
