Solve Ampere's Law Problem for Uniform Current Density
In summary, the conversation discusses using the integral form of Ampere's law to find the magnetic field in a conducting slab with uniform current density. The relevant equation is the integral form of Ampere's law, which states that the integral of the magnetic field dotted into the path is equal to the permeability of free space times the enclosed current. The person is unsure how to apply this to a cylindrical system and suggests using a rectangular loop for integration.
Crazy Gnome
A conducting slab of thickness a is bounded by the planes z= [tex]\pm[/tex]a/2 and carries a uniform current density J=J (y hat)
Use the integral form of Ampere's law to to find magnetic field everywhere
2. Relevant equations
Integral for of Amperes law: Integral (B \bullet ds) = \mu 0 Jenclosed
All of the examples in class and in the book use cylindrical symmetry so I was a bit perplexed as how to approach taking an integral over a closed path dotted into a B in cylindrical coordinates.
Try using a rectangular loop for the integration. Each leg of the loop is either perpendicular or parallel to B.
To solve this problem, we can use the integral form of Ampere's law and choose a closed path that follows the symmetry of the problem. In this case, we can choose a rectangular path that follows the edges of the conducting slab.
Starting at the bottom left corner of the slab, we can label the sides of the rectangle as follows:
- The bottom side: from (x=-a/2, y=-a/2, z=-a/2) to (x=a/2, y=-a/2, z=-a/2)
- The right side: from (x=a/2, y=-a/2, z=-a/2) to (x=a/2, y=a/2, z=-a/2)
- The top side: from (x=a/2, y=a/2, z=-a/2) to (x=-a/2, y=a/2, z=-a/2)
- The left side: from (x=-a/2, y=a/2, z=-a/2) to (x=-a/2, y=-a/2, z=-a/2)
Using the symmetry of the problem, we can see that the magnetic field will only have a non-zero component along the z-direction. Therefore, we can rewrite the integral form of Ampere's law as:
∫B·ds = μ0Jenclosed = μ0Jaz∫ds
Where Jaz is the component of the current density along the z-direction.
Now, we can break down the integral into four parts, corresponding to the four sides of the rectangle:
∫B·ds = μ0Jaz∫ds = μ0Jaz∫(dx,y,z = -a/2)^(x=a/2,y,z=-a/2) + μ0Jaz∫(x=a/2,y,z=-a/2)^(x=a/2,y,z=a/2) + μ0Jaz∫(x=a/2,y,z=a/2)^(x=-a/2,y,z=a/2) + μ0Jaz∫(x=-a/2,y,z=a/2)^(x=-a/2,y,z=-a/2)
Since the current density Jaz is constant throughout the slab, we can pull it out of the integral:
∫B·ds =
1. What is Ampere's Law?
Ampere's Law is a mathematical equation that relates the magnetic field produced by a current-carrying wire to the current and distance from the wire. It is named after French physicist André-Marie Ampère.
2. What is a Uniform Current Density?
A Uniform Current Density is a term used to describe a situation where the current is evenly distributed throughout a wire or conductor. This means that the current is the same at every point along the wire.
3. How do you use Ampere's Law to solve a problem?
To solve a problem using Ampere's Law for Uniform Current Density, you will need to determine the current, the distance from the wire, and the shape of the current-carrying wire. Then, you can plug these values into the equation and solve for the magnetic field at a specific point.
4. What are the units of measurement for Ampere's Law?
The units of measurement for Ampere's Law are amperes (A) for current, meters (m) for distance, and teslas (T) for magnetic field.
5. Can Ampere's Law be used for non-uniform current density?
No, Ampere's Law can only be used for uniform current density. If the current is not evenly distributed, the equation will not accurately represent the magnetic field produced by the current.
