Ampere's Law: Toroid
  1. Sep 27, 2009 #1
    A toroid of a circular cross section whose center is at the origin and the axis the same as the z-axis has 1000 turns with po=10cm, a=1cm. If the toroid carries a 100mA current, find |H| at (6cm, 9cm, 0).
    2. Relevant equations
    How do I calculate |H| at certain points?
    3. The attempt at a solution
    Knowing that H = NI / 2*pi*po, and po - a < p < po + a, I have found p to be between 9cm and 11 cm.
    I assumed H = H1 + H2.
    If H1 = ((1000)(0.1) / 2 * pi * 0.9) * (0.06x + 0.09y) = 10.61x + 15.92y
    Similarly, H2 is the same except p = 0.11 m. Therefore H2=8.68x + 13.02y.
    After adding the two, and then finding the magnitude I get 34.8 A/m, but the answer is 147.1 A/m.
  3. Sep 28, 2009 #2
    kuruman
    I don't know what H1 and H2 are and you don't explain. Look, you have a formula that gives H as a function of the radius. Everywhere at that radius the field is the same. So, at what radius is point (6 cm, 9 cm, 0)?
  4. Sep 28, 2009 #3
    H1 and H2 are H, except one is calculated at 9cm and one is calculated at 11cm. H, I'm assuming, is the sum.
  5. Sep 28, 2009 #4
    kuruman
    No it is not the sum. At a given radius r
    [tex]H=\mu_{0}\frac{N I}{2\pi r}[/tex]
    The above expression says "You give me the radius, I will give you H."
  6. Sep 28, 2009 #5
    Ok thank you! That helps a lot. Even if I do find 'r', what do I do with the a and p values?
  7. Sep 28, 2009 #6
    kuruman
    What do the a and p values represent?
Similar Discussions: Ampere's Law: Toroid
  1. Ampere's Law (Replies: 18)
  2. Amperes Law (Replies: 1)
Loading...
