Amplify current output?
  1. Jan 27, 2010 #1
    Does anyone have advice for how I can amplify a current output for low cost.
    Here are the details:
    I'd like to use a pulse generator to actuate a solenoid valve. The pulse generator has a variable voltage output (0-20V), and a current output of 0.2 - 0.22 A.
    The solenoid valve requires at least 12 V, and at least 0.32 A.
    I first thought I might simply be able to use a transistor, but I'm having a difficult time finding the right one.
    Does anyone know if this approach might work (and maybe able to recommend a transistor)?
    Or have a suggestion for a better approach?
    Thanks very much,
  3. Jan 27, 2010 #2
    If the solenoid requires 0.3 amps, you might consider using a small signal transistor like the PN2222A which is rated to handle 0.6 amps.
    Here is a possible schematic. The diode will protect the transistor from high voltage spikes coming from the solenoid when it is switched on/off.
    http://www.vlearnvshare.com/home/images/articles/NPN-DRIVER1.GIF [Broken]
  4. Jan 27, 2010 #3
    Thanks very much! I'll give it a try.
Similar Threads - Amplify current output Date
AC-Coupled Current Input to Amplifier Sep 29, 2015
Op-amp: Current and bandwidth question Mar 17, 2015
How to amplify the current of an AC signal? Sep 13, 2013
Amplifier supply current. Aug 5, 2013
Current Shunt Amplifier Module Oct 31, 2012
