Homework Help: Amplitude of a spring
  1. May 18, 2015 #1
    Lets say I have a spring, resting at a length x at t = 0 seconds, with a spring constant k, and at the end is attached with a block with mass m. I give the block a velocity v in the -x direction.
    Now I'm asked to find the Amplitude.
    2. Relevant equations
    3. The attempt at a solution
    Here, I'm thinking, KEmax = PEmax = 1/2 m v2 = 1/2 k A2
    since the highest velocity is the initial 'push' i give it, is it safe to say I have every variable to solve for A(amplitude)?
  3. May 18, 2015 #2
    berkeman
    Staff: Mentor
    Looks good to me so far... :smile:
  4. May 18, 2015 #3
    so when is 1/2 k A2 = 1/2 mv2 + 1/2 k x2?
    is that when you don't know the max velocity? is that when you know a given velocity and distance at a given time?
  5. May 18, 2015 #4
    berkeman
    Staff: Mentor
    This looks correct for when v = the velocity at zero displacement.
    This is confusing. Why are you adding the two terms on the RHS?
  6. May 18, 2015 #5
    I think to add up the total energy at a given time so KEmax =PEmax = 1/2 k x2 at a given time + 1/2 mv2 at a given time
    I could be wrong though
  7. May 18, 2015 #6
    berkeman
    Staff: Mentor
    That does look correct, but you should add subscripts to the velocity v to make it clear what you mean in each case. KE max is at zero displacement, and PE max is at maximum displacement. And KE + PE at any given point is equal to KE max or PE max.
  8. May 18, 2015 #7
    KEmax =PEmax = 1/2 k x^2 at a given time + 1/2 mv^2 at a given time = 1/2 k A 2
    then I can solve for Amplitude, if I'm given a time where displacement isn't 0
    correct?
  9. May 18, 2015 #8
    berkeman
    Staff: Mentor
    Not quite.
    KEmax = PEmax = 1/2 k A^2 = 1/2 m v(x=0)^2. At any given time KEmax = PEmax = 1/2 k x^2 + 1/2 m v^2
    Where A = max amplitude.
  10. May 18, 2015 #9
    isn't that what i typed out?
  11. May 18, 2015 #10
    berkeman
    Staff: Mentor
    Not the way I read it. I bolded the things I changed and added.
Have something to add?
Draft saved Draft deleted
Loading...
