What is the amplitude of the resulting oscillations?
In summary, the homework statement talks about a mass hanging from a spring with a force constant of 50 N/m. An oscillating force is applied and the amplitude of the oscillations is 0.15 m.
yecko
A mass of 2.0 kg hangs from a spring with a force constant of 50 N/m. An oscillating force F = (4.8 N) cos[(3.0 rad/s)t] is applied to the mass. What is the amplitude of the resulting oscillations? Neglect damping. Answer: 0.15 m
F=kx , the mass only change the equilibrium position, amplitude is when max F thus cos is equal to 1
F=4.8N, k=50N/m
x=F/k
=4.8/50
=0.096m.
What's wrong with my calculation? Thanks
F=4.8N, k=50N/m
x=F/k
=4.8/50
=0.096m.
The mass experiences three forces, gravity, mg, spring force, (-kx) and the driving force F. Gravity changes the equilibrium position only, but F is not equal to kx.
Yes, I understand and i have mentioned it in the first post
So what to calculate?
Thanks
yecko said:
Yes, I have mentioned it
Thanks
The amplitude of vibration.
I know, frankly its the question~
i mean how i can calculate in order to get the amplitude of vibration (the answer!)
what are the formulae to be used and the steps for getting the answer, if my steps are wrong (whats wrong?? why F is not equal to k*dx ?)
thanks
(ps. what I mentioned in the first posts are things all i understand... please tell me what i have misunderstood...)
Really wish I could help you here, but no matter how I look at this question I get the same answer you do, and the only answer I can find online is formatting that makes no sense;
- A = ( F m ) ( 2 2 ) 2 ( b 2 m ) 2 = ( 4.8 N 2 kg ) [ ( 3 s 1 ) 2 ( 50 N m 2 kg ) ] 2 + = 0.15 m -
I'd keep trying but its like 2 am, hope somebody else helps you find your answer.
well, indeed the format goes wrong by directly copy and paste would make it unreadable
it seems we are on the another half of the planet:) it is still early here~
however i am going to have exam tomorrow, hope all problems in my exercises can be settled by today:)
thank you very much
Can you write Newton's second law for this object? Remember, you have to take two forces into account.
The object does SHM -simple harmonic motion. What is its displacement x in terms of time?
You certainly learned about driven oscillation. The object will oscillate with the frequency of the diving force after some time. What is the angular frequency of the external force?
See the x(t) function of the forced oscillator in http://www.physics.louisville.edu/cldavis/phys298/notes/resonance.html, with the damping b neglected.
F=ma
x=A cos(ωt+Θ)
ω=3
yecko said:
F=ma
F = ma is valid if F means the net force applied to the object. What is that net force in this case?
yecko said:
x=A cos(ωt+Θ)ω=3
The driving force is FD=4.8 cos(3t) . The elastic force is Fe=-kx. What is the net force?
If what you said FD=kx, the net force is zero, and the acceleration is zero. The object can not oscillate.
Fd+Fe?
Why? I mean when the spring length is amplitude, force is max, accerleration is max.
yecko said:
Fd+Fe?
Yes, and what is in terms of time and x?
You speak about the spring force. But there are two forces, applied on the object, and the acceleration is (Fd+Fe)/m.
Fd=4.8 cos(3t) , Fe=-kx
F(net)=4.8 cos(3t) +-kx
are they contradict?
F(net)=4.8 cos(3t) -kx
Yes. So ma=4.8 cos(3t) -kx. And the object performs SHM, with the frequency of the driving force, so x=Bcos(3t+θ). What is the acceleration then?
nothing
nothing
yecko said:
x=Acos(3t+θ) [A=amplitude?]
a=-9Acos(3t+θ)
yes. And ma=4.8cos(3t)-kx. What should be A and θ?
A = 0.096(?) and θ=0
step:50Acos(3t+θ)=4.8cos(3t)
whats wrong with my calculation?
How did you get the equation 50Acos(3t+θ)=4.8cos(3t)? You think that the acceleration is zero? That is wrong.
substitute a and x into ma=4.8cos(3t)-kx
Where is a?
oh
i got it
i mixed up the plus and minus sign only
thank you very much for your help!
1. What is the definition of amplitude in oscillations?
The amplitude of an oscillation is the maximum displacement of the oscillating object from its equilibrium position.
2. How is amplitude measured in oscillations?
Amplitude is typically measured in units of length, such as meters or centimeters, depending on the scale of the oscillation.
3. What factors affect the amplitude of oscillations?
The amplitude of oscillations can be affected by the frequency of the oscillation, the mass of the oscillating object, and the amount of energy input into the system.
4. Can the amplitude of oscillations change over time?
Yes, the amplitude of oscillations can change over time. This is known as damping, where the amplitude decreases due to the dissipation of energy in the system.
5. How does amplitude relate to the strength of an oscillation?
The amplitude of an oscillation is directly related to the strength or intensity of the oscillation. A higher amplitude indicates a stronger oscillation, while a lower amplitude indicates a weaker oscillation.
