1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Amplitude question
  1. Jul 5, 2008 #1
    Hello, I am having trouble finding the A in this problem. I found T=1/2=.5, I found K =31.55n/m. I tried using the formula KA2=MV2+KX2 to find amplitude but ended up with A=0.0435m
    This just does'nt seem right . I used .05m for a value of X. Does anybody know what I am doing wrong?
    A 200 g mass attached to a horizontal spring oscillates at a frequency of 2.0 Hz. At one instant, the mass is at x=5.0cm and has Vx=.30 cm/s determine the period, Vmax, Amplitude, and the total energy.
  3. Jul 5, 2008 #2
    The V should be Vx=-30cm/s
  4. Jul 5, 2008 #3
    alphysicist
    Hi nicksim117,
    Can you list the details of what you did to get 0.0435m? It looks to me like you have a calculation error (or maybe you're interpreting the equation incorrectly?). Did you square the velocity?
  5. Jul 5, 2008 #4
    Redbelly98
    Staff Emeritus
    Everything in the equation is a positive quantity, since v and x get squared. There is just no way for A to end up being less than x.
  6. Jul 5, 2008 #5
    k looks ok
    use energy methods E=K+U
    you know v,x and k solve for A. the rest is pretty straight forward.
  7. Jul 6, 2008 #6
    Hello, I am having trouble solving this problem trying to find A I keep getting an amplitude which is less than my distance can anybody see what i am doing wrong?
    A 200g mass attached to a horizontal spring oscillates at a frequency of 2.0 hz. At one instant, the mass is at X=5cm and has a V=-30cm/s Determine:
    The period T=.5
    The amplitude?
    the Vmax
    the total energy
    2. Relevant equations
    KA2=MV2+KX2 or A2=(MV2+KX2)/K
    3. The attempt at a solution
    solve for A using 1/2KA2=1/2MV2+1/2KX2= (.5)(31.55)A2=
    > (.5)(.2)(-.3m/s)+(.5)(31.55)(.05m)2
    > ==15.77A2=-.009+.0394375==.0304375/15.77=A2===.001930==A=.04393m
    > V=-30cm/s
    > K=31.55n/m
    > X=5cm
    > M=.2kg
    A=.04393m
  8. Jul 6, 2008 #7
    I don't know why i keep getting that answer. I posted the equation worked out as a new thread.
    [Edit by Doc Al: I merged the two threads. Do not create multiple threads on the same problem.]​
  9. Jul 6, 2008 #8
    Doc Al
    Staff: Mentor
    Your approach is fine, but recheck your arithmetic.
  10. Jul 6, 2008 #9
    alphysicist
    You squared the velocity, so it should be positive 0.009
  11. Jul 6, 2008 #10
    Doc Al
    Staff: Mentor
    There ya go! :wink:
  12. Jul 6, 2008 #11
    Thank you!!
  13. Jul 6, 2008 #12
    For the same problem i am ask to report total energy in the system. When I use the formula and value at that instantE=K+U=1/2MV2+1/2KX2 I get .0484J. When I use the same formula but Vmax and A are used in place of V and X I get .0954J Should these values be the same because energy is conserved.
  14. Jul 6, 2008 #13
    Doc Al
    Staff: Mentor
    Do v=Vmax and x=A occur at the same point? :wink:
    Energy is most definitely conserved--that should tell you that something is wrong with your thinking.
  15. Jul 6, 2008 #14
    Ok, that make sense, so If energy is conserved and I use the values given in the problem and plug them into E=K+U=1/2MV2+1/2KX2 to find total energy in the system they should equal the value of either Umax 1/2 KA2or Kmax 1/2MV2 not both added together.
  16. Jul 6, 2008 #15
    Doc Al
    Staff: Mentor
    Exactly.
  17. Jul 6, 2008 #16
    thanks for your help!
Have something to add?
Similar Discussions: Amplitude question
  1. Amplitude Question (Replies: 0)
Loading...
