An ant on the edge of a disc
  • Thread starter omc1
omc1
100
An ant positioned on the very edge of a Beatles record that is 14.80 cm in radius revolves through an angle of 70.0o as the disk turns. What is the ant's path length?
What is the magnitude of the ant's displacement?
L=Rtheta
i was able to find the path length to 0.181 m and that's right but i can't find the displacement which seems like it should be easy...i used c^2=a^2+b^2 but that didnt work then i used costheta that didnt work so i used s=rtheta and that didnt work so ...please help, thanks
Answers and Replies
phinds
Insights Author
2022 Award
18,133
10,949
This gives you an isosceles triangle with two known sides and the angle between them also known ... how hard can it be ? Divide it into two right triangles and go from there.
omc1
100
i did that and CAPA is still rejecting my answer...
gneill
Mentor
20,946
2,892
Why don't you write out, in full, one of your attempts so that we can see what might be going wrong?
omc1
100
i did radius times tan35 equal the opposite leg then multiply by two ...207
gneill
Mentor
20,946
2,892
Ah, but I don't see that expression being correct. The radius is not the adjacent leg of the triangle.
omc1
100
ic i found my mistake, thanks!
Suggested for: An ant on the edge of a disc
  • Last Post
  • Last Post
