Homework Help: An automatic charger
  1. Jan 11, 2008 #1
    i need to build a circuit which can charge a 12V 10 A battery to reach a votltage A and then stops charging until it reaches a voltage B it will rechrge again . i wanna do this using thyristor
    2. Relevant equations
    3. The attempt at a solution
    i found a circuit for a 12 v 4A it will reach A but i donno how to control B
  3. Jan 11, 2008 #2
    dlgoff
  4. Jan 12, 2008 #3
    no sir it wont work cz 1st i ne the two voltagers not to be A and -A i need them to be A and B second i need to do that using thyristor
  5. Jan 12, 2008 #4
    dlgoff
    With a voltage divider, you can get A and B to be any posivite value you want between the positive and negative terminals of your battery. Then use these values as inputs to a couple of op-amps used as comparators. You should then be able use the comparator outputs to find a way to switch your charger on/off while using thyristors.
  6. Jan 13, 2008 #5
    well it is a good idea but i canot use op amps sorry for wasting ur time any other ideas . i just can use thyristor diodes and resistors
