An electromagnetic paradox?
  • Thread starter johne1618
johne1618
371
Consider the system below comprising a pair of oppositely charged parallel plates, connected by a rigid rod of length [itex]r[/itex], constrained to move in the x-direction.
The forces on the plates from the Coulomb electric fields and the magnetic forces are all in the vertical direction so that they do not affect the motion of the system.
The only fields that do affect the system are the horizontal radiation fields due to the acceleration of the charged plates.
Let us assume that we initially apply a force [itex]F_0[/itex] so that we have:
[tex]F_0 = m a_0[/tex]
As charge [itex]+q[/itex] has an acceleration [itex]a_0[/itex] then it will produce a horizontal electric field at the negative plate given by:
[tex]E_+ = \frac{-qa_0}{4 \pi \epsilon_0 c^2 r}[/tex]
This will lead to a horizontal force [itex]f_0[/itex] on the negative plate, pointing towards the right, given by:
[tex]f_0 = \frac{q^2a_0}{4 \pi \epsilon_0 c^2 r}[/tex]
Likewise as charge [itex]-q[/itex] has an acceleration [itex]a_0[/itex] then it will produce a horizontal electric field at the positive plate given by:
[tex]E_- = \frac{qa_0}{4 \pi \epsilon_0 c^2 r}[/tex]
Again this will lead to a horizontal force [itex]f_0[/itex] on the positive plate, pointing towards the right, given by:
Thus the total force on the system is now given by:
[tex]F_1 = F_0 + 2f_0[/tex]
Therefore the system has an increased acceleration given by:
[tex]a_1 = \frac{F_1}{m}[/tex]
[tex]a_1 = a_0 \left(1+\frac{q^2}{2\pi\epsilon_0c^2rm}\right)[/tex]
The argument can be repeated indefinitely leading to the calculated acceleration diverging exponentially.
What's gone wrong?
There are no [itex]\dot{a}[/itex] terms in the calculation so I don't think the Abraham-Lorentz reaction force due to the production of electromagnetic radiation can save the day. A positive feedback involving forces and accelerations seems to preclude a consistent initial value for the acceleration.
Here's my (rather radical) solution: perhaps the mass has to change to ensure that the acceleration stays constant.
Perhaps we have:
[tex]F_0 = m_0 a_0[/tex]
[tex]F_1 = m_1 a_0[/tex]
Therefore:
[tex]\frac{m_1}{m_0} = \frac{F_1}{F_0}[/tex]
[tex] \frac{m_1}{m_0} = \frac{1}{m_0a_0}\left(m_0a_0+\frac{q^2a_0}{2\pi\epsilon_0c^2r}\right)[/tex]
[tex]m_1 = m_0 + \frac{q^2}{2\pi\epsilon_0c^2r}[/tex]
Answers and Replies
UltrafastPED
216
These are not static fields unless you are in the comoving frame.
A relativistic treatment is required ... try it with a constant acceleration and see what you get.
johne1618
371
Can I just conduct the argument in a comoving frame then?
I don't know how to do the argument relativistically with a constant acceleration.
Jano L.
74
Your calculation of the EM force neglects retarded character of EM field. If you calculate with exact expression for the retarded EM field, you will get many new terms that will influence the value of the EM force on the plates. In the first instant of period when the force is applied, the EM force has no acceleration component, so the acceleration is determined by F/m. The acceleration field kicks in only after time delay r/c.
After this delay, the acceleration field acts on the plates, but then there is also the velocity dependent field, which has opposite direction. Perhaps it is this velocity field that prevents the acceleration to get too high.
Likes 1 person
johne1618
371
Thanks for the reply.
I don't think the retardation time changes the effect. Also I think one could make the argument in a comoving frame where the velocities of the plates are zero.
I think the best way to imagine the experiment is to simply drop the system in a gravitational field. The induced electric forces would cause the system to accelerate faster than gravity which of course is forbidden by the equivalence principle.
UltrafastPED
216
Note that the comoving frame is stationary wrt the plates ... so you would both fall together.
Then by the equivalence principle what would you expect to see?
johne1618
371
To be honest I'm not quite sure of the definition of comoving frame actually.
Is it an inertial frame that has the same instantaneous velocity as the plates or is it a frame that has both the same velocity and the same acceleration as the plates?
If it's the later then I expect the gravitational force + electromagnetic force on the plates to be balanced by an inertial force due to the plates' standard mass + an extra inertial force due to the plates' "electromagnetic mass".
Jano L.
74
The retardation does not change the acceleration field much if the acceleration is constant, but it plays role in the other, velocity-dependent terms. You have to consider them thoroughly. When you do, you will most likely find that there is no such run away behaviour.
Adding gravitational field means adding theory of gravity (you mention equivalence principle), which means things will get more unnecessarily complicated. It is better to consider your problem in an inertial frame, with external force F acting on the system.
The other part of the problem in your consideration is, I think, the iterative way you use to find the acceleration. Consider this equation:
ma = F + ka,
which suggests this iterative equation:
a_{n+1} = a_{n} + ca_{n}
with ##a_0 = F/m##, ##c = k/m.##
Using your iterative procedure, we would get
a_1 = a_0 + c a_0 = a_0(1+c)
a_2 = a_1 + ca_1 = a_0(1+c)^2
and obviously sequence ##a_{n}## goes to infinity.
However, the correct solution of the original equation is ##a = F/(m-k)##.
Obviously the iterative way does not lead to correct solution.
Dale
Mentor
Insights Author
2021 Award
33,218
10,600
Why would you think that?
You don't have any sort of indefinite number of forces to repeat anything with. You have two forces, the mechanical force and the EM force. So your net force has two terms, one of which is a function of the acceleration. Plug in your net force on one side and ma on the other side and you have one equation in one unknown, a. Solve for a.
That is it. No diverging exponential acceleration. This is no different from any other f=ma problem except that solving for a involves a little more algebra than simply dividing both sides by m.
johne1618
371
If the effect was instantaneous then as Jano says one would just solve the equation:
[tex]m a = F + k a.[/tex]
I think there is an iterative, positive feedback, effect here because of the time delay [itex]dt[/itex] between the plates accelerating and the subsequent electromagnetic force on the plates.
[tex]F(t+dt) = F(t) + k a(t)[/tex]
[tex]F(t) = m a(t)[/tex]
[tex]F(t+dt) = m a(t+dt)[/tex]
Thus we have
[tex]a(t+dt) = a(t)(1+k/m)[/tex]
[tex]\int da/a = \int k/m dt[/tex]
[tex]a(t)=a_0e^{kt/m}[/tex]
Dale
Mentor
Insights Author
2021 Award
33,218
10,600
The acceleration is uniform, is it not (it must be given the expression you used for the field)? Then the delay time is not important because nothing has changed during the propagation.
Again, you don't have any sort of indefinite number of forces to repeat anything with. You have two forces, the mechanical force and the EM force. So your net force has two terms, one of which is a function of the acceleration. Plug in your net force on one side and ma on the other side and you have one equation in one unknown, a. Solve for a.
BruceW
3,611
121
this is an interesting 'problem'... The slight nudge will cause a slight change in the electric field so at a time ##r/c## later, each charge will feel (for a short time) an acceleration in the horizontal direction. and this acceleration causes another slight change in the electric field, which causes another acceleration at time ##r/c## later. So the charges will keep doing these little accelerations at every ##r/c## time interval.
I think maybe the answer is simply that in the case when there is only one charge, when you give it a nudge, some of that energy just gets radiated outwards, and never comes back. But when you have the two charges in this set-up, some of that radiated energy will not escape to infinity, and it is this that causes the little 'hops' forward. I don't think the accelerations will diverge. I suspect the accelerations will slowly die down with time.
Anyway, I'm not sure if any of this is right. It is just my first guess.
Jano L.
74
I think there is an iterative, positive feedback, effect here because of the time delay dt between the plates accelerating and the subsequent electromagnetic force on the plates.
F(t+dt)=F(t)+ka(t)
Aha, so you do consider delays. That is better, but the above equation is not correct. You simply have to take the full expression for the electromagnetic force and then justify any particular simplification. The EM force is not just ka(t).
Dale
Mentor
Insights Author
2021 Award
33,218
10,600
We are guaranteed that the accelerations will not diverge by Poynting's theorem.
Under the steady acceleration case you have simply a f=ma where f is a function of a. One equation in one unkown. Obviously no diverging.
In the impulsive acceleration case you will have to solve more complicated equations, but you are guaranteed that they will not diverge either.
johne1618
371
Having read your post about delays I now think they are an essential part of the argument. The delay between acceleration and electromagnetic force is what causes the positive feedback.
I think my analysis is ok for non-relativistic velocities - I admit I don't know how to make a more accurate calculation.
chingel
303
If you want to do it iteratively, you need to consider that with the new acceleration you only need to add the extra force coming from the field from the extra acceleration, but you added the whole force due to the field after every step, while you should have added just the extra force.
So it is like [itex]a_{1}=a_{0}+a_{0}\times k/m[/itex], then [itex]a_{2}=a_{1}+(a_{1}-a_{0})\times k/m[/itex] and not [itex]a_{2}=a_{1}+a_{1}\times k/m[/itex], then [itex]a_{3}=a_{2}+(a_{2}-a_{1})\times k/m[/itex] etc and see where the values converge. Or the easier way is to do it the way as was pointed out before, [itex]a=a_{0}+a\times k/m[/itex] and solve for a.
It does seem weird that the system seems to push itself. I think that if the charges give away radiation and energy, then this needs to be accounted for and would result in additional forces. However googling the radiation of an uniformly accelerating charge I get conflicting answers and it gets over my head into general relativity and stuff.
johne1618
371
Maybe I can just say that I start with an initial acceleration [itex]a_0[/itex] so that we have
$$m a_n = k a_{n-1}$$
$$a_n = (k/m)a_{n-1}$$
$$a_n = (k/m)^n a_0$$
Each time step takes a time [itex]r/c[/itex] so that we can write:
$$a(t)=\left(\frac{k}{m}\right)^{ct/r}a_0$$
BruceW
3,611
121
Just to make sure, 'k' is
##k=\frac{q^2}{2\pi\epsilon_0c^2r}##
right? yeah, the iterative law ##a_n=(k/m)^na_0## looks right. But I am not sure about your last equation. I guess you are assuming the two charges are very close or something?
Anyway, your equation ##a_n=(k/m)^na_0## is very insightful. If you think about it, to have a non-relativistic limit, we must have k<<m, so therefore the accelerations will get smaller and smaller. And if we have k to be the same order as m, then we have the relativistic case, and in that case, the equation
##E_+ = \frac{-qa_0}{4 \pi \epsilon_0 c^2 r}##
Is not correct anyway, so the equation ##a_n=(k/m)^na_0## is also likely to be incorrect in the relativistic case.
edit: to be clear, in the relativistic case, the relativistic mass of the charges will change, and other weird stuff will happen, so we would not be allowed to use the nice assumptions that we have been using. Although, maybe the equation
will still work... It assumes that the change in velocity is small compared to the speed of light. So I guess this equation can still be true even when k>m
chingel
303
If you are using iteration, then it should go something like this: the force [itex]m\times a_{0}[/itex] pushes the system, assume it to start accelerating with [itex]a_{0}[/itex]. But since the acceleration causes extra force which is proportional to the acceleration, you have an additional extra force [itex]k\times a_{0}[/itex]. Combining these forces you have a new acceleration [itex]a_{1}[/itex]. Now considering the system accelerating at [itex]a_{1}[/itex], you must now not add an entire new force from the electric field with magnitude [itex]k\times a_{1}[/itex], instead you have to add only the extra force that comes from the increased acceleration, so that it's magnitude is [itex]k\times (a_{1}-a_{0})[/itex]. You have to account for the increased force from the electric field, not add a whole new force, because otherwise you would count the same force many times.
If you solve it, it is equivalent to solving this equation for a [itex]m\times a=m\times a_{0}+k\times a[/itex].
However this whole analysis is problematic, because energy and momentum seem to not be conserved if it simply pushes itself. You have to account for the radiated energy and momentum as well, which should cause extra forces.
johne1618
371
Yes ##k=\frac{q^2}{2\pi\epsilon_0c^2r}##
I assume that during each step an electromagnetic influence travels across the system from an accelerating charge to a receiving charge . This will take a time ##\Delta t = r/c## where ##r## is the distance between the charges.
Thus in a time ##t## the number of steps ##n## will be given by:
$$n = t / \Delta t = ct /r$$
I don't think ##k \sim m## or even ##k>m## is a relativistic case. To attain it you just need a large charge ##q## and a small distance ##r##.
I think the equation ##E_+ = \frac{-qa_0}{4 \pi \epsilon_0 c^2 r}## is already relativistically correct.
To sum up I don't think relativity cures the problem.
Perhaps though one needs to include the effects of a radiation reaction force as the acceleration changes. The Abraham-Lorentz reaction force depends on the rate of change of acceleration ##\dot{a}##. If we put such a term into the recurrence relation we get:
$$m\ a_n = k\ a_{n-1} - b\ \dot{a}_n$$
We can write the rate of change on acceleration as:
$$\dot{a}_n = \frac{a_n - a_{n-1}}{\Delta t}$$
Using ##\Delta t = r/c## as the time interval between steps we have:
$$\dot{a}_n = \frac{c}{r}\left(a_n - a_{n-1}\right)$$
Therefore substituting into the recurrence relation we have:
$$m\ a_n = k\ a_{n-1} - \frac{bc}{r}\left(a_n - a_{n-1}\right)$$
$$(m + \frac{bc}{r})a_n = (k + \frac{bc}{r})a_{n-1}$$
$$a_n = \left(\frac{k+bc/r}{m+bc/r}\right)^na_0$$
Thus if the ratio in brackets is greater than ##1## then the acceleration will diverge.
$$k+bc/r > m+bc/r$$
$$k > m$$
This is the same result as we have without the radiation reaction force.
Dale
Mentor
Insights Author
2021 Award
33,218
10,600
What problem? Poynting's theorem guarantees that there is no problem if you actually use Maxwell's equations to do this. The only problem arises if you use a numerical method that is bad.
johne1618
371
Well you do the calculation using Maxwell's equations then.
Dale
Mentor
Insights Author
2021 Award
33,218
10,600
I might do so on Sunday if I have time, but this is your topic and your interest, not mine. The effort properly should come from you.
The fact is that we are guaranteed that there is no diverging acceleration by Poynting's theorem. Poynting's theorem follows directly from Maxwell's equations and the Lorentz force law. Therefore, if you are using some other method to calculate the force and you get a diverging acceleration then you know that your calculation method is flawed.
It isn't an issue of any paradox in EM. It is simply a bad calculation, and lack of a good calculation doesn't make a bad calculation good.
johne1618
371
ok - sorry for my last post.
johne1618
371
Hi all,
An acquaintence has pointed me towards "An electric dipole in self-accelerated transverse motion" by F. H. J. Cornish. Unfortunately you have to pay for the article or rent it for free for 5 mins.
http://ajp.aapt.org/resource/1/ajpias/v54/i2/p166_s1?isAuthorized=no&ver=pdfcov [Broken]
A detailed relativistic calculation shows that the dipole should move with a constant proper acceleration given by:
$$a = \left(\frac{2c^2}{d}\right)\left[\left(\frac{e^2}{2mc^2d}\right)^{2/3}-1\right]^{1/2}$$
where ##e## and ##-e## are the charges, each charge has mass ##m##, ##d## is the distance between them and ##d < e^2/2mc^2## (cgs units used).
As the acceleration is constant the author states that the Lorentz-Dirac radiation reaction forces on each charge vanish and therefore do not contribute to the motion.
chingel
303
Considering conservation of momentum, how can one charge push another without feeling an opposite reaction force? If it simply does that then momentum wouldn't be conserved.
johne1618
371
True.
That's why I think it is not enough just to consider a retarded electromagnetic interaction from an accelerated charge to another that is instantaneously at rest. I think there must also be an advanced electromagnetic interaction that travels backwards in time from the stationary charge to the accelerated one producing a counter-balancing force.
Nugatory
Mentor
13,978
7,533
The charges aren't pushing against each other, they're pushing against the electromagnetic field in their immediate neighborhood. That field has momentum associated with it, and if you include its momentum you'll find that momentum is conserved at every step of the interaction between the particles.
chingel
303
Does that mean that light would be emitted with such momentum so that conservation of momentum would hold?
What about energy conservation? The system has more kinetic energy than was put in and then there is also the energy of the light.
  • #31
Nugatory
Mentor
13,978
7,533
Yes, both energy and momentum are conserved; the electromagnetic field can hold energy as well as momentum. The total increase in kinetic energy, plus the energy radiated away by light, plus the change in potential energy if the two charged particles change their distance, will add up to exactly the amount of work that was done to accelerate the first particle.
Really, this entire process is no more mysterious than what happens when you have two masses connected by a spring, you give one of the masses a shove and it takes a moment for the other one to start moving. At any moment you may not be able to make the energy and momentum of the two masses add properly, but that doesn't mean momentum or energy conservation is being violated; it means you forgot to add in the energy and momentum of the spring.
  • #32
chingel
303
I'm saying that if the system accelerates itself and radiates away light, energy would not seem to be conserved and therefore it is questionable that it would accelerate itself.
However, as was previously posted, it seems to self-accelerate, about which an article was posted.
  • #33
Dale
Mentor
Insights Author
2021 Award
33,218
10,600
Hi all,
Very interesting. Too bad for the paywall.
All of the bona-fide mathematical paradoxes in classical EM that I know about have to do with mathematical problems from treating classical point particles. They go away if you avoid classical point particles (which don't exist anyway). I suspect that is the case here also.
Unfortunately, I was planning on using the Lienard Wiechert potential in my solution, so my approach may wind up with the same problem.
  • #34
johne1618
371
I'm trying to understand if the problem is to do with quantum mechanics or classical EM.
If there is a problem then I think it's to do with high electric fields causing vacuum polarization.
If an electric field has a high enough energy density then electron-positron pairs will be generated which means that we must hand over the problem to quantum field theory.
Thus for vacuum polarization we have:
$$ \epsilon_0 E^2 = \frac{m_ec^2}{\lambda^3}$$
where ##\lambda## is the electron Compton wavelength given by ##\lambda = h/m_ec##.
Thus
$$ E^2 = \frac{m_e^4 c^5}{\epsilon_0 h^3} $$
$$ E \approx 10^{15} V/m$$
In order to show the anomalous acceleration a system's electric potential energy has be roughly equal in magnitude to its rest mass energy.
Can I construct a parallel plate capacitor whose electrical energy is of the same order as its rest mass energy without using electric fields greater than ##10^{15} V/m##?
If ##\rho## is the mass density of the plates, ##w## is the thickness of the plates, ##A## is the area of the plates and ##d## is the separation of the plates then a capacitor whose rest mass is equal to its electrical energy is given by:
$$\rho A w c^2 = \epsilon_0 E^2 A d$$
$$E^2 = \frac{\rho c^2}{\epsilon_0}\frac{w}{d}$$
Assuming ##\rho=10^3 kg/m^3## we have:
$$E = 10^{15} \times \sqrt{\frac{w}{d}}\ V/m$$
Thus as long as the ratio of plate thickness to separation is small enough we can avoid vacuum polarization electric field strengths inside the capacitor.
Thus I think the paradox lies with classical EM rather than with quantum field theory.
  • #35
Dale
Mentor
Insights Author
2021 Award
33,218
10,600
The problem, as stated, is one of classical EM, as is the paper you cited.
Suggested for: An electromagnetic paradox?
  • Last Post
22K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
10K
