An electronic circuit ?
Eng_Electro
http://up4.w6w.net/upload/17-03-2006/w6w_2006031704465627806cb7.JPG [Broken]
for the following circuit find and draw V(out) if the V(in) signal is a sine wave with amplitude of 10V (Consider all diodes to be ideal)
This is the problem , could any one plz solve it 4 me ?:?:
10x
Answers and Replies
mezarashi
652
The policy is that we don't do homework for you. Would you please explain how you have tried to solve this problem so far?
Eng_Electro
ok , no problem
i've solved it but i dont know if it is true
i have taken two values
one as 10 v
and other as - 10 v
and i have got as result two out put voltages (one for 10 v and one for
- 10 v)
and solved the problem normally after that
but , is my solving correct ? is this how i should solve the problem ?
berkeman
Mentor
63,247
14,212
Just start by drawing the Vo versus Vi graph for a linearly increasing Vi from -10V to +10V. You wll find different behavior regions where the various diodes go from Off to On. Figure out what these voltages are where the diode behaviors change (how many regions are there?), and solve each one separately. Then you can plot the Vo response to a Vi sine wave to finish answering the homework question.
Averagesupernova
989
No berkeman, the OP said to consider all diodes to be ideal. Eng_Electo, your approach is correct. Tell us what your answers are.
berkeman
Mentor
63,247
14,212
Even with ideal diodes, it seems like the input impedance and transfer function will change with input voltage, based on the bias voltages in series with the diodes. Pushing the input voltage high is a lot easier, for example, than pulling it low where the first clamp stage will be operating.
Suggested for: An electronic circuit ?
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
