An example of a set
irony of truth
90
I want to know some examples of an infinite set S with a least upper bound that is not an accumulation point of S. Is this an example... (-oo, 10]?
Answers and Replies
No, it's not. Every point in that set is an accumulation point of it.
An example is
[tex] \left[0 , 1 \right] \cup \{ 2 \} [/tex].
edit: Another example is Z- ={-1,-2,-3,-4,-5...}, the set of negative integers. It's clearly infinite, bounded above, and does not have any accumulation points.
irony of truth
90
Hmmm, thank you for the help...
By the way, suppose I have Λ as my least upper bound of a set S but Λ is not in S. I want to know how this Λ is an accumulation point....
My friend told me that for any ε > 0, he can show that there is a point s belonging to S such that Λ - ε < s < Λ. To end up the proof, he used the definition of accumulation point... how do I prove this...? :D
HallsofIvy
43,021
970
Suppose &Lambda; is a least upper bound of a set, A, but not in the set itself. Since &Lamba; is an upper bound for A, there are no members of A larger than &lambda;. Given &epsilon;> 0 suppose there were no members of A between &Lambda;-&epsilon; and &Lambda;. Then there would be no members of A larger than &Lambda;-&epsilon;. That means that &Lamba;-&epsilon; is an upper bound for A, contradicting the fact that &Lambda; is the least upper bound.
irony of truth
90
So the concept of accumulation point comes in here "Given ε> 0 suppose there were no members of A between Λ-ε and Λ. ...".
irony of truth
90
HallsofIvy said:
Suppose Λ is a least upper bound of a set, A, but not in the set itself. Since &Lamba; is an upper bound for A, there are no members of A larger than λ. Given ε> 0 suppose there were no members of A between Λ-ε and Λ. Then there would be no members of A larger than Λ-ε. That means that &Lamba;-ε is an upper bound for A, contradicting the fact that Λ is the least upper bound.
May I clarify something.... is this the proof for ( I have restated my problem) "Assume that Λ is the least upper bound of a set S but Λ is not in S. Show that Λ is an accumulation point of S" ?
Yes, you're right.
irony of truth
90
Ah.. ok.. I asked that because I thought the proof only shows that /\ is the least upper bound... and not that /\ is an accumulation point.
From the proof HallsofIvy stated, how did /\ turn out in the end to be an accumulation point (I apologize for being "slow")
Suggested for: An example of a set
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
