An intro question about the magnification factor of an SEM
In summary, an SEM image of xylem vessels in a corn root shows the vessels magnified by a factor of 600. The diameter of the vessel itself is 0.12 cm, and the cross-sectional area has been increased by a factor of 360000 in the micrograph. There are no similar example problems in the text, causing frustration for the individual.
fatmike6305
An intro question about the "magnification factor" of an SEM
A scanning electron micrograph of xylem vessels in a corn root shows the vessels magnified by a factor of 600.?
In the micrograph the xylem vessel is 7.0 cm in diameter.
(a) What is the diameter of the vessel itself?
(b) By what factor has the cross-sectional area of the vessel been increased in the micrograph?
I calculated that A) is 1.2e-2, but was incorrect. Not sure if it's the notation that I'm using. Also, confused on B.
I'd like to point out that there are absolutely NO example problems of anything similar in the text. Frustrating
. A) The diameter of the vessel itself is 0.12 cm.B) The cross-sectional area of the vessel has been increased by a factor of 360000 (6002).
I understand your frustration with not having examples to reference for this specific topic. However, I can provide some guidance on how to approach these types of questions.
First, let's define the magnification factor of an SEM. This refers to the ratio between the size of the image produced by the SEM and the actual size of the object being imaged. In this case, the magnification factor is 600, meaning the image is 600 times larger than the actual object.
For part (a), we need to use the magnification factor to calculate the diameter of the vessel. We can set up a proportion:
600 = (diameter of image) / (diameter of vessel)
Solving for the diameter of the vessel, we get:
diameter of vessel = (diameter of image) / 600
Plugging in the given values, we get:
diameter of vessel = 7.0 cm / 600 = 1.2 x 10^-2 cm
So your initial calculation was correct, but it's important to keep track of units and use the correct notation (e.g. using scientific notation for very small numbers).
For part (b), we need to calculate the factor by which the cross-sectional area of the vessel has been increased in the micrograph. This can be done by using the formula for the area of a circle (A= πr^2) and comparing the area of the vessel in the micrograph (A') to the actual area of the vessel (A).
A' = π (diameter of image / 2)^2 = π (3.5 cm)^2 = 38.48 cm^2
A = π (diameter of vessel / 2)^2 = π (1.2 x 10^-2 cm / 2)^2 = 1.13 x 10^-4 cm^2
The factor by which the area has been increased is therefore:
A' / A = (38.48 cm^2) / (1.13 x 10^-4 cm^2) = 3.41 x 10^8
This means that the cross-sectional area of the vessel has been increased by a factor of approximately 3.41 x 10^8 in the micrograph.
I hope this helps clarify the calculations and concept of magnification factor in SEM images. Remember, practice and repetition are key in understanding
Related to An intro question about the magnification factor of an SEM
What is the magnification factor of an SEM?
The magnification factor of an SEM (scanning electron microscope) refers to the amount that the image is enlarged or zoomed in. It is typically expressed as a ratio, such as 1000x, which means the image is 1000 times larger than the actual size of the object being viewed.
How is the magnification factor calculated in an SEM?
The magnification factor in an SEM is calculated by dividing the size of the image by the actual size of the object. For example, if the image is 1 mm and the actual size of the object is 0.001 mm, the magnification factor would be 1000x.
What factors can affect the magnification factor in an SEM?
Several factors can affect the magnification factor in an SEM, including the voltage and current settings, the type of detector used, the type of sample preparation, and the quality of the microscope's lenses. Controlling these factors can help improve the accuracy and clarity of the magnified image.
How does the magnification factor impact image resolution in an SEM?
The magnification factor directly affects the image resolution in an SEM. As the magnification increases, the image becomes more detailed and allows for the visualization of smaller structures on the sample. However, too high of a magnification factor can also decrease the overall quality of the image if the microscope's settings are not optimized.
What is the maximum possible magnification factor in an SEM?
The maximum possible magnification factor in an SEM can vary depending on the specific microscope model and its capabilities. In general, modern SEMs can achieve magnifications of up to 2 million times, but this may be limited by factors such as the sample size and the type of detector being used.
  • Materials and Chemical Engineering
  • Aerospace Engineering
11K
