Analysis help
Let X=R^2 and the distance be the usual Euclidean distance. If C and D are non-empty sets of R^2 and we have:
C+D := {y ϵ R^2 | there exists c ϵ C and dϵD s.t c+d = y}
A) What is C+D if the open balls are C= ball((0.5,0.5);2) and D=ball((0.5,2.5);1)
B) Same as A) expect D is now a closed ball
C) same as a) except D={(l,-1)|l ϵ R}
D) Is the following true? If C,D are non-empty subsets of R^2 s.t C is open, then the sum C+D is open.
A) It to, C+D is just the union set of all points in C and D s.t. for all c ϵ C and dϵD, c + d = x.
I think this set is open, but not sure how to describe it in more detail. Any ideas?
B) Same description as A but with boundary too?
C) not sure
D) I think this is false since C could be open and D could be closed, and so their sum would not be open.
Answers and Replies
3,297
Hi metric_space! :smile:
Let's make the problem a bit easier first by taking D just a point of the ball.
For example, (0.5,2.5) is an element of D, so (0.5,2.5)+C will be a subset of C+D. But what does (0.5,2.5) look like?
Try it for some other elements, for example (1,2.5) will be in D. So what does (1,2.5)+C look like?
In general, the set C+D will be the union of all sets d+C with d in D. Thus
[tex]C+D=\bigcup_{d\in D}(d+C)[/tex]
So once you've figured out how the d+C look like, you'll know what the C+D looks like...
Same remarks as above.
This is in fact true! Try to figure this out by using my remarks above...
hm..not sure how to proceed
3,297
Well, what will (0.5,2.5)+C look like?
3,297
No, it will be more than one point. In fact
[tex](0.5,2.5)+C=\{(0.5,2.5)+c~\vert~c\in C\}[/tex]
try to sketch this...
That's the point (0.5,2.5) plus the circle centered at (0.5,0.5) with radius 2?
3,297
No :frown:
A typical element of (0.5,2.5)+C has the form (0.5,2.5)+c with [itex]c\in C[/tex]. Maybe take some elements c in C and sketch (0.5,2.5)+c. Maybe you can see what happens then?
I can't see what happens -- I have the sketch but that's not helping.
3,297
Try sketching 10-15 points, you'll see what happens soon enough!
does the set consists of a half circle that's the intersection between C + D?
3,297
No. If I told you that (0.5,2.5)+C is an open ball, could you perhaps figure out which one?
I'm just drawing a circle with a pt...but unable to make progress...I think I need a hint
Think of it as a transformation. You've got some ball C, centered at (0.5,0.5) with a radius of 2. Now, C+(0.5,2.5) is the set of all points in C, in addition with the point (0.5,2.5). So, where in R^2 are these points now?
Related Threads on Analysis help
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
