Homework Help: Analysis of a function
  1. Jan 13, 2017 #1
    Hi guys I have been stuck on this for the better part of a day today and was wondering if anyone could help. I really cant seem to know even where to start.
    I have to Analyse and sketch the function: $$xy^2-x^2y+x+y=2$$
    I have not got a lot in the attempt solution because I am very lost. Can someone please give me an idea on how to tackle these types of problems.
    2. Relevant equations
    3. The attempt at a solution
    1. $$x=0, y=2, y=0, x=2$$#
  3. Jan 13, 2017 #2
    andrewkirk
    If you think of ##x## as a constant what you have is a quadratic equation in ##y##, which you can solve, and then plot the ##(x,y)## pairs that are the solutions of that equation. By doing that for a number of different values of ##x## you can identify enough points to sketch to form an idea of the shape of the function.
  4. Jan 13, 2017 #3
    This is the equation, that I got this morning, $$y=\frac{\left(x^2-1\right)\pm\sqrt{\left(1-x^2\right)^2-4x\left(x-2\right)}}{2x}$$. But this is where I was getting stuck because I could not find values for the quartic >0. This is why I thought this method I was doing was wrong. The values I got for x^4-6x+8x+1=0 was x=-1 and x=-0.544.
  5. Jan 13, 2017 #4
    Mark44
    Staff: Mentor
    Your solution for y looks fine, as far as you took it, but when you simplify the radical you should get ##x^4 - 6x^2 + 8x + 1##, which is different from what you show. Also, -1 is not a root of the equation ####x^4 - 6x^2 + 8x + 1 = 0##.
    Use andrewkirk's suggestion of putting in values of x to get y values. Do this to get a number of points to get an idea of what the graph looks like.
  6. Jan 13, 2017 #5
    haruspex
    On a whim, I tried the rotation x+y=u, x-y=v. This gave uv = -2±√(4+8v+v4). Marginally simpler? It makes an asymptote easy to find.
  7. Jan 14, 2017 #6
    Thanks @Mark44 and @haruspex for the help. @haruspex at this moment in time I have not come across rotation only in matrices so ur method has sparked interest. Could you either expand on this on maybe point me to a web site to read up of this method myself?
  8. Jan 14, 2017 #7
    haruspex
    It's just a change of coordinates. The u and v axes are at 45 degrees to the x and y axes. Actually it is not a pure rotation, there is also an expansion by a factor of √2. To make it a pure rotation you would have to use u=(x+y)/√2 etc. but for the purposes of sketching the graph you can fix that up later.
    Here is another trick to try...
    Figure out some forbidden regions. For what range of x does y have no solutions, and vice versa? Likewise u and v?
Have something to add?
Draft saved Draft deleted
