Analysis of structure
  1. Jul 12, 2007 #1
    If the loads are all vertical in a truss, will there be horizontal component on the hinge of the given truss?
    Does the presence of the horizontal component depends on the design of the truss?
  3. Jul 12, 2007 #2
    russ_watters
    Staff: Mentor
    What hinge? Could you give us a diagram...?
  4. Jul 12, 2007 #3
    Astronuc
    Staff Emeritus
    Usually there is a later component in a truss, or a diagonal element. However, I would expect some lateral element because structures are 3-D.
  5. Jul 12, 2007 #4
    diagram:http://instruct1.cit.cornell.edu/Courses/ansys/truss/images/truss.jpg [Broken]
    Will there be a horizontal force component at A?
  6. Jul 13, 2007 #5
    mgb_phys
    Yes - I would have thought that was pretty obvious looking at the diagram.
    Consider taking moments about point C.
  7. Jul 13, 2007 #6
    FredGarvin
    Just to echo what mgb_phys mentioned, you should be able to visualize the forces at A in your mind. If you were to pull down at that point, can you not convince yourself that the member AB will not pull diagonally on point A?
  8. Jul 13, 2007 #7
    mgb_phys
    Thanks - I was worried that I sounded a bit condescending - then I noticed the cornel.edu address and figured this wasn't a grade4 student!
