Homework Help: Analytic geometry: ellipse
  1. May 21, 2012 #1
    1. a hall that is 10 ft. wide has a ceiling that is a semi-ellipse. the ceiling is 10 ft high at the sides and 12 ft high in the center find its equation with the x axis horizontal and the origin at the center of the ellipse.
    2. Relevant equations
    x^2/a^2 + y^2/b^2 = 1
    3. The attempt at a solution
    The difference between the height at the ceiling and the sides is 12-10 = 2 ft. This is the value of b.
    I assume that the vertices of the ellipse are 10 feet apart, the same as the width of the hall. This means that the major axis is 10 ft. Therefore, a = 10/2 =5.
    The equation of the ellipse is x^2/25 + y^2/4 = 1
    p.s. i think i got the right answer but i need a better solution.
    the point p1(x1,y1) lies outside the circle whose center is at (h,k) and whose radius is r. if T is the length of the tangent from p1 to the circle, prove that t2=(x1-h)^2+y1-k)^2-r^2
    (x-h)^2+(y-k)^2=r^2
    P (x1,y1) (x-h)^2+(y-k)^2=r^2
    i used distance formula
    P (x1,y1) to (x-h)^2+(y-k)^2-r^2=0
    = (x1-h)^2+y1-k)^2-r^2
Draft saved Draft deleted
