Analytic Solution For Equilibrium Point
In summary, the conversation discusses a problem involving a uniform rod rotating freely in a vertical plane. The goal is to find an analytic solution for the equilibrium points, but it is uncertain if this is possible. The equation for the equilibrium points involves various constants and the coordinate phi. While there are four possible solutions, only two will exist for certain values of L. The conversation also mentions using trigonometric identities or the double angle formula to simplify the equation and potentially find an analytic solution.
DLinkage
I recently made an interesting problem involving a uniform rod. I would like to find an analytic solution to this problem however I do not know if this is possible. The equation yielding the equilibrium points is given by
omega^2*R*cos(phi) + omega^2*(L/2)*cos(phi)*sin(phi) + g*sin(phi) = 0
omega is a constant being a measure of angular velocity
R is also a predetermined radius
L is a constant but we are to consider the variations L < R, L = R, L > R
phi is the coordinate we are trying tofind equilibrium points for.
The problem is a uniform rod rotating freely in a vertical plane whos basepoint is a radial distance R away from the primary axis of rotation. The length of the rod is L, and its vertical orientation is given by phi measured clockwise from the vertical.
Note that there are 4 angles that yield a solution if L is long enough, (this is not to say that all 4 are stable). Only two will exist however (between 0 and 180 degrees if L is less than this k*R (k > 1)). We can easily find stability by either looking at the numerical solution and checking concavity (When L = k*R the concavity becomes zero at the critical points and it is tangent to the line y = 0). So this is all great for insight and such but is there an analytic solution? Pretty much this is becoming a math problem with independent coefficients. So if we normalize all the terms by omega^2*r the nwe have something like
cos(phi) + A*cos(phi)*sin(phi) + B*sin(phi) = 0
Anyone have any ideas? I'm completely stumped (tried s(2a) = 2cos(a)sin(a))
also sin(a) = sqrt(1-cos(a)^2) hasnt gotten me anywhere either. Thanks
It sounds like you've done a lot of work on this problem already and have made some progress. Have you tried using the double angle formula to simplify the equation? It might be helpful to break it down into two parts and solve it that way. Another approach might be to use trigonometric identities such as the law of cosines or the law of sines. I'm not sure if any of these will help you find an analytic solution, but it's worth a shot. Good luck!
I would first commend you on your interesting problem involving a uniform rod. The equation you have provided is certainly complex, but it is not impossible to find an analytic solution. It may require some mathematical manipulation and possibly the use of numerical methods, but it is certainly within the realm of possibility.
One approach you could take is to try to simplify the equation by reducing the number of variables. For example, you could try to eliminate the constant omega by substituting it with a variable, say x, and then try to solve for x in terms of phi. This may lead to a more manageable equation that can be solved analytically.
Another approach would be to use numerical methods to approximate the solution. This involves using a computer program to iteratively solve the equation and find the equilibrium points. This may not give you an exact solution, but it can provide valuable insights and allow you to visualize the problem in different scenarios.
I would also recommend consulting with other experts in the field, such as mathematicians or physicists, who may have more experience in solving similar problems. Collaborating with others can often lead to new insights and solutions.
In conclusion, while finding an analytic solution to your problem may be challenging, it is certainly possible with the right approach and resources. Keep exploring and don't be afraid to seek help from others in the scientific community.
1. What is an analytic solution for equilibrium point?
An analytic solution for equilibrium point is a mathematical method used to find the point at which two or more variables are in balance or equilibrium. It involves solving a set of equations or inequalities to determine the values of the variables that satisfy the given conditions.
2. Why is it important to find the equilibrium point?
Finding the equilibrium point is important in many scientific fields such as physics, chemistry, and economics. It helps to understand the behavior of a system or process and predict its future state. It also allows for the optimization of the system by identifying the most stable and efficient point of operation.
3. What are the steps involved in finding an analytic solution for equilibrium point?
The steps involved in finding an analytic solution for equilibrium point may vary depending on the specific problem. However, in general, the steps include setting up the equations or inequalities, simplifying them, and solving for the variables. This may involve using algebraic manipulation, substitution, or graphical methods.
4. Can an analytic solution for equilibrium point be applied to all systems?
No, an analytic solution for equilibrium point may not be applicable to all systems. It is only suitable for systems that can be described by a set of mathematical equations or inequalities. Some systems may be too complex or unpredictable to be solved analytically, and numerical methods may be required.
5. How can an analytic solution for equilibrium point be used in real-life situations?
Analytic solutions for equilibrium point can be used in many real-life situations, such as determining the optimal production level for a company to maximize profit, finding the balance between supply and demand in a market, or calculating the ideal mixture of ingredients in a chemical reaction. It can also be applied in engineering and physics to design stable and efficient systems.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
