• Support PF! Buy your school textbooks, materials and every day products Here!
Analyzing Simple Circuits
  • Engineering
  • Thread starter TheTopGun
Hello! I'm having difficulty analyzing this circuit and determining the currents I1,I2,I3.
Ohm's Law
Kirchoffs Laws
Current and Volatage divider
So far all I can manage is simplifying the circuit, Im sure im suppose to use current or voltage divider I just can't work out where.
Using software simulation the values should be around ....I1=0.5404, I2=0.8109, I3= -0.2702mA
Any help on which rules and where to apply them would be much appreciated!
~thanks
Answers and Replies
berkeman
Mentor
57,497
7,523
Ohm's Law
Kirchoffs Laws
~thanks
Your simplified circuit is correct except you have a typo for the left resistor. Should be kOhms, not Ohms.
In problems like this, I prefer to write the KCL equations, and just solve them simultaneously. That's the most intuitive technique for me, and almost always works without modification.
So this is a pretty simple circuit -- call the voltage at the top node V1, and write the one KCL equation for that node. You can then solve for that voltage, which lets you solve for the 3 currents that the problem is asking for. In problems with multiple nodes, just write the KCL equations for each node and solve the equations simultaneously.
I prefer to write the KCL equation(s) as the sum of all the currents out of each node equal zero.
Can you show us your work given those hints?
Likes 1 person
Ahh thankyou very much. I was messing around with equations I didn't need. I just wrote out the Ohms, KCL & KVL equations then solved simultaneously, came out perfect.
Once again, thanks :)
Related Threads on Analyzing Simple Circuits
