Angle between 2 vectors. accuracy
  1. Mar 25, 2013 #1
    EDIT UPDATE
    so basically I figured this out. it was apparently what i was rotating around.
    Now i can rotate much mroe finely I'm not sure how to close this though so i'm just adding this here
    this has to with a programming problem where i am rotating an object so it snaps into alignment with the face of another object.
    because i've been told arctangent2 is more accurate (for vectors near parallel)
    and my issue is near parallel vectors i'm using that
    basically i take the crossproduct of the normal and the inverse normal of 2 planes
    to find the axis
    (vectors 1 and 2 are normalized, atan apparently doesnt care but they are because
    they come spat out that way)
    vector1 = normal of plane were rotating
    vector2 = normal of plane were rotating to
    axis = vector1 * -vector2
    that should give me the axis to from from 1 to 2
    then the angle i have as
    y = magnitude of axis
    x = dot product of (vector1, -vector2)
    angle = arctangent2(y,x)
    is there any way to make this more accurate though maybe squaring or something
    basically the issue is that if the dot product is like .99999999
    and the magnitude of the axis is like .01
    i end up through inprecision flipping back and forth I guess
    (my axis goes from 0,0,.7 to 0,0,-.7) for example
    which I think whats happening is i'm rotating just a bit too far, then needing to rotate the opposite way back but going a bit to far.
    currently using that I can get to within about .1radians or 5 degrees of accuracy. (that is i basically tell it if the angle is less than .1 radians to call that parallel and not rotate, it's close enough, otherwise i have this vibrating effect as the object constantly rotates quickly back and forth a few degrees).
    That actually seems quite large to me for a floating point number and im wondering if perhaps i'm doing this wrong.
    Also I can use quanternions
    i've been told that a quanternion can be made by going
    quanternion x,y,z = cross product of vectors
    w = 1 + dot product of vectors (basically nearly there it'd be 1.999999999)
    But i dont get quanternions at all so i'm not sure if thats accurate
    also not sure if thats like basically how much I would add
    like current quanternion rotation + the calculate rotation
    or
    current quan rotation just equals calculated
    lastly im not sure if what point i rotate around matters
    thats is
    right now if i have a box right I rotate around the magical point in the middle of the square by angle degrees around axis
    should i in fact rotate teh object as it were around the point in the mdidle of whatever plane on the side of the box was hit?
    basically i'm worried that rotating around the center of the cube is actually moving the plane itself and is part of the reason for my lack of accuracy.
    I'm having trouble visualizing the differences in my head though so im not sure.
Draft saved Draft deleted
