Angle between position vectors
  1. Sep 24, 2016 #1
    FInd the angle theta between AB and AC. a-1.7m, b=1.3m
    masteringengineering.com says my answer is wrong. I'm not sure of any other way to do the problem. Please advise.
    2. Relevant equations
    A(3, 0, 0) B(0, -.75, 1.3) C(0, 1.7, 1.5)
    3. The attempt at a solution
    r(AC)= -3i +1.7j + 1.5k
    r(AB)= -3i -.75j +1.3k
    r(ACmag)*r(ABmag)= 13.3
    r(AB)*r(AC)= 9.67
    arccos(9.67/13.3)= 43.4
  3. Sep 24, 2016 #2
    Nidum
    Can you see a way of getting the lengths AB , BC and CA using right angle triangles and Pythagoras' Theorem ?
  4. Sep 24, 2016 #3
    BC= sqrt(2.45^2+.2^2)= 2.46
    AB= 3.54
    AC= 3.76
    I found AB & AC by finding the magnitude of the direction vectors r. If this is correct, I assume I take the tangent but I'm not sure which side would be considered adjacent.
  5. Sep 25, 2016 #4
    ehild
    Wrong.
    Keep 4 digit during the calculations.
  6. Sep 25, 2016 #5
    ehild
    BC is not needed. Your initial approach was correct, but the magnitude of the vectors are wrong.
  7. Sep 25, 2016 #6
    13.3 is the magnitude of each vector multiplied together (3.76*3.54). 9.76 is obtained by multiplying the vectors together then adding the result (-3i-.75j+1.3k)(-3i+1.7k+1.5k)= (9-1.28+1.95) = 9.76. So, I figured arccos(9.76/13.3 )= 43.4
  8. Sep 25, 2016 #7
    So, by carrying out my decimal to four places I get 12.6136 for a magnitude. so, arccos(9.76/12.6136)= 39.9
  9. Sep 25, 2016 #8
    ehild
    The product of the two vectors is not 9.76, but close. The result for the angle is all right. Write it out with two significant digits.
Have something to add?
Draft saved Draft deleted
Similar Discussions: Angle between position vectors
  1. Angle Between 2 Vectors (Replies: 20)
Loading...
